LinkBack (1) | Thread Tools |
#1
Look Ma! My First Post!
info needed....EFI to Carb conversion
hi... I have a 88 Thunderbird with the 5.0 EFI and I want to convert to a carb set-up...
I want to use a Edlebrock Performer manifold and a Holley 600cfm with elect choke. I want to use a MSD dist with their 6A box. I want to limit the amount of wire cutting...I don't want the factory computer to work at all... can this be done?? |
yes it can, scrap all the vacuum hoses, and covert to a chevy style HEI distributor, or a Duraspark distributor which is a little better. The HEI distributor just needs three wires, and a vacuum for the timing advance, it easy do to.
![]() Good luck
Or just get an MSD mechanical dizzy and run a very limited timing curve.
You can still have all your factory gauges work too if you can find the right wires...
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
07 Turbo Focus
12.93 @ 105mph
I'm in the process of doing a carb conversion.
What you're going to need to do is get rid of the MAF, the fuel rails, fuel injectors, the obvious stuff. Get rid of the engine harness and ECU as it'll be useless and dead weight. Remove the electronic distributor and everything from the lower intake manifold up. So long as you get a short intake manifold, you shouldn't have problems with hood clearance. If you do, then get convertible engine mounts and the engine will sit lower. Here's a list of what you'll need, -Intake Manifold for Carb -Carburater (600 is good for stock-ish motor) -You can use the OEM fuel pump just use a really good FPR with a return line to the tank as a carb only requires 6-8psi fuel pressure -Block off the EGR completely (Did I say that out loud?) -Find nuts to plug the O2 bungs -Find a distributor with vacuum advance since you will be deleting the ECU -Get a duraspark or MSD ignition box -Get a air cleaner for carb -Find a 1985 or earlier GT and grab the throttle cable for carb as well as fuel hardlines to the FPR This is what I'm doing, you might do it differently, but I'm wiring my fuel pump, ignitions, and electric fan into a switch board so I can just turn them on when I want to start the car. If I've forgotten anything I'll let you know, but that's about it. If you could find a 1985 or earlier donor car, that would be best since you'd have everything right there. Another way you could deal with the fuel pressure issue would be to drop the tank and swap it with a tank from a pre-1985 GT for the pull through fuel line, and then hook up an electric fuel pump for about 8psi. I personally think the FPR route would be much easier and less hassle, it's the route I'm going. You can still use the same roller cam, same heads, bottom end, etc... nothing there has to change. This is a copy/paste of what I posted in the fuel injection to carb swap thread.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
1993 Mustang GT
unk right now as fast as i can push
why would you want to go carb? i understand it looks cleaner i guess but really gains? my experience is just messing with them when i go some where else altitude problems and stuff
not to sound like a moocher buuut
im trying to convert my 88 T bird over to mass air and im having trouble finding the parts where i live. Is there a chance any of you stang guys have a mass air w/pigtail and computer off a 93 stang by any chance? i got the S.O. 5.0 v8, and i have all the parts to do an H.O. conversion, but i'd like to swap out speed density and put in mass air. any ideas fellas!
#7 | |
90 GT 393 5 spd, 467 rwhp 480 rwtq 92 coupe, R/S 308 5 spd 93 coupe, 2.3 5 spd
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/153348-info-needed-efi-carb-conversion.html
| Thread 351 EFI to carb ?? | Index :: Bronco Fix - For the 1966-77 early Ford Bronco | BoardReader | This thread | Refback | May 9th, 2011 03:43 PM | |
Threads Similar to: info needed....EFI to Carb conversion
| Carb to EFI conversion | galzamar | 5.0 Mustangs | 8 | March 19th, 2010 10:19 PM |
| conversion efi to carb?'s | 93lx306dev | 5.0 Mustangs | 4 | September 7th, 2008 12:45 PM |
| Carb to EFI conversion | hull | 5.0 Mustangs | 0 | August 16th, 2008 06:12 PM |
| EFI to Carb | bigdaddy09 | 5.0 Mustangs | 1 | April 21st, 2008 04:47 PM |
| 5.0 efi to carb conversion help | berkdog84 | Audio/Video | 0 | January 30th, 2008 08:36 PM |
