Expected gains from a GT40 intake on an otherwise stock motor - Page 2
Old February 23rd, 2010, 03:56 PM   #21
JBIGBOOTSY's Avatar
1990 LX hatch
Quick question. How do you get an exact measurement of an engines VE?
Old February 23rd, 2010, 04:34 PM   #22
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Well, your mass air sensor knows how much air is being pulled through the intake. That gives you actual air consumed.
Take the half of the displacement of the motor multiplied by the rpm to see what "ideal" consumption would be.
Actual air consumed divided by ideal consumption gives you the VE.
EDIT: I realize this doesn't take the mass of fuel into account, so the above won't be "exact". You can use the fuel map to see exactly how much fuel is added per the air consumed, rpm, and throttle position. That'll most likely involve some conversions from cubic feet of air to pounds of air, as most domestic injectors are rated by pounds of fuel.
For example, if you ignore fuel, as it makes life easier:
A 5.0 turning 4500 rpm theroetically should consume 2.5L*4500rpm, or 11,250 Liters of air/fuel mixture per minute (that's 397 cubic feet for you non-metric types). If the mass air sensor is is showing consumption of 369cfm, 369/397 = .93, or 93%.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old February 23rd, 2010, 05:12 PM   #23
ryans88gt's Avatar
Originally Posted by MustangMatt96GT View Post
yes i will agree... im just saying from my experience that is a HUGE $$$$ motor.... but it is hard to get a 100% VE motor NA cheap, and pretty easy to do when you are compressing air before hand.
Actually Ford claims their new 32v 5.0L motor operates at 110% VE at peak torque. Making 400+ hp from 300ish cubes in an emissions street motor is pretty impressive, but not crazy expensive.
Old February 23rd, 2010, 07:08 PM   #24
Proud American
MustangMatt96GT's Avatar
Thats pretty impressive...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Threads Similar to: Expected gains from a GT40 intake on an otherwise stock motor
Intake gains dschack V6 Mustangs 18 January 3rd, 2010 03:44 PM
gains expected from x pipe and high flow cats? Black Sunshine 07 2005 - 2010 13 July 14th, 2008 01:59 PM
rwhp gains expected?? 01sta1k3r 99-04 11 January 30th, 2008 11:39 PM
lower intake gains 02ponypackage V6 Mustangs 67 September 12th, 2007 08:31 PM
