Alignment settings
I am trying to find out the correct alignment settings for my 93 Notch with a front K-Member, coil-over kit, caster camber plates and a tie rod bump steer kit? I have been told that there is a "performance setting" Is that true and if so does anyone know what the settings are. I know with all the aftermarket parts I have on the front end the suspension geometry is different... So it would make sense that the settings would be different.. I dont want to have to buy new front tires every 5-7000 miles cuz of uneven wear or chopping..
'88 LX body '91 GT D/T
8.7 in the 1/8th
If I were you, find a good tire shop, ie Tires Plus, Expert Tire, Firestone, etc and tell them what you have. My last car, I replaced all the suspension with aftermarket and lowered it with larger wheels. Told the tech I wanted just a hint of negative camber for cornering stability. He dialed it in PERFECTLY!! I pulled over 1G on a 300ft skid after the upgrades. In a FF Import nontheless. As far as having the factory or OEM specs, any shop can find that. Unless you are doing the alignment yourself, let them do the work.
Can't say I blame ya on the tire wear issue. That shit sucks.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
I dont feel comfortable taking advice from a tire shop that does not do custom alignments. I prefer getting it from someone who knows Mustangs. I will not be doin any hard cornering. It is a street car but I only drag race with it.. Thanks though..
8.7 in the 1/8th
I realize that your car and my old one are like daylight and bananas, lol, but I had GREAT results with Tires Plus.
Gimme a lil bit and I'll see what I can find for ya. So I don't fuck it all up, will your OEM specs still hold true w/ all the aftermarket suspension upgrades? Ie; tow, caster, camber, bump stop height, etc.?
I dont have a Tires plus where I live.. As far as the settings go I dont know if they do. I think with the caster camber plates you want at least 3 degrees of caster or as much as you can get out of it... Other than that I dont know..
8.7 in the 1/8th
OK. I'll roll w/ that. Sit tight bro.
Hey thanks man i'm lookin too...
8.7 in the 1/8th
Hey bro!!! Check this link. A dude on there did basically the same thing.
http://forums.stangnet.com/showthread.php?t=655570
thanks man
8.7 in the 1/8th
Not a problem. I only hope its got info you can actually use.
It has a little but not all!! Good find though... thanks man!!!
Here's a common theme I've found on the Net:
The MM Instructions for their K-Member state: Alignment recommendations when using the MM K- member: For street driven cars, set caster at 6 degrees positive; camber at ¾ degree negative; toe-in set to a total of 1/16".
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
Threads Similar to: Alignment settings
| Clock Settings? Lol | SantanielloITA | V6 Mustangs | 11 | November 11th, 2007 02:28 PM |
| Timing Settings...... | roksoldier | 5.0 Mustangs | 1 | September 14th, 2007 07:51 PM |
| tps settings | Fastpitchdad | 5.0 Mustangs | 5 | June 25th, 2007 05:54 PM |
| KYB AGX settings??? | mustangman9550 | General Tech | 1 | February 25th, 2007 06:07 PM |
| Predator Settings | yellowstang98 | Modular Mustangs | 3 | February 10th, 2007 10:16 AM |
