Starter Question/ Problem (Heat Soak)
Old March 2nd, 2007, 09:18 PM   #1
xjer88 is on a distinguished road
Ok, I have a slight issue that im sure many of you have dealt with already. When I drive for a while my starter gets heat soaked and doesnt want to turn over the engine. It is a higher compression 347 stroker so i can understand why its having a problem. I have BBK shorty headers. Soooo my question is what do you recommend? I have already got a better battery which seemed to help some, and I have a higher amp alternator on its way. I have a feeling thats not gonna do it. So i was thinking about a new starter. The mean green is an awesome starter from what ive heard, but the price is killer at $300. The other option is to just go with a PMGR(Permanent Magnet Gear-Reduction) Starter from a place like PA Performance or such. And save about $150 over the Green. But my main concern is the Heat Soak. Anybody running a PMGR starter and not have heat soak problems? TIA ---Sam
Old March 2nd, 2007, 09:26 PM   #2
Stangzilla's Avatar
Stangzilla is on a distinguished road
Wrap it with heat wrap. I have long tubes in my car and a high torque starter. I have not had to wrap it yet.... I have a 347cid also..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 2nd, 2007, 09:37 PM   #3
Yeah i was just looking at wrap on ebay. Maybe I will order some tonight.
Thanks for your Input. But i still think I should go with a better starter becuase even when its cold it barely wants to turn over. What starter brand are you running?
Old March 2nd, 2007, 09:53 PM   #4
Stangzilla's Avatar
I dont know it came with the car before I put in the new motor..
Old March 2nd, 2007, 10:36 PM   #5
Hahahaha, next time ill ask a hatchback owner. :wink
Thanks Stangzilla. Think im just gonna go with the high torque starter and wrap, cheaper and same affects as Mean Greens starter.
Old March 2nd, 2007, 10:39 PM   #6
Stangzilla's Avatar
Ahhh your just jealous...
Old March 2nd, 2007, 10:52 PM   #7
Your right notchbacks are the Shiznizzle. What 347cid kit you running?
Old March 2nd, 2007, 11:02 PM   #8
Stangzilla's Avatar
I bought a 347 Street Fighter crate motor with AFR 185 heads from Coast High Performance 450hp..
Old March 3rd, 2007, 03:00 AM   #9
Nice Setup, im running a Probe kit with Trickflow Top twisted Wedge heads, Built by AMP. 430hp.
Old March 3rd, 2007, 12:23 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Starter Question/ Problem (Heat Soak)
Buy a Powermaster starter or you can try a 92-93 Mustang starter.
Old March 4th, 2007, 03:25 AM   #11
Stangzilla's Avatar
Thank you.... U 2....
Old March 4th, 2007, 11:00 AM   #12
nolife's Avatar
91GT, 88GT, 02GT
Your starter heat problem may really be just a warn out starter. I had the same problem but it went away with nothing more then replacing mine with a cheapo rebuilt local parts store starter. A standard typical shorty setup should not cause starter heat problems. It would not hurt to wrap your starter but I think you need a new one.
Old March 4th, 2007, 07:00 PM   #13
Powermaster looks like a good investment, and i could run down to Summit and pick one up later this week, along with seats. Thanks for the Tip.
Old March 7th, 2007, 10:55 PM   #14
86blkmustang's Avatar
86blkmustang is on a distinguished road
Send a message via AIM to 86blkmustang Send a message via Yahoo to 86blkmustang
I thought I had a heat problem but come to find out it was just the body and battery ground needed to be cleaned?
Threads Similar to: Starter Question/ Problem (Heat Soak)
Starter/solenoid problem WIKD 2.3 Mustangs 2 October 4th, 2007 07:15 PM
starter solenoid question fastford3388 5.0 Mustangs 2 April 23rd, 2007 10:40 PM
starter problem superbeef1000 99-04 1 March 23rd, 2007 10:38 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
Heat question 89LX50 5.0 Mustangs 6 October 21st, 2005 11:39 PM
