#21 |
'88 LX body '91 GT D/T
8.7 in the 1/8th
UPR for the stiff stuff.
M/T drag radials are a great tire choice.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#22 |
^+1
#23 |
+1 To you get what you pay for! You will be fine running UPR U/L's though... there are alot of people who run their suspension on 10 second cars all day long. I just wont buy their products becuase when I think of UPR I think of billet internerior pieces... just something that I have stuck in my head, dont know if I could buy from them personally but alot of people do with no problems. I guess its just a piece of mind kind of thing. I stick w/ all MM & D&D. Expensive but hopefully worth it! Well see in a few weeks, I have a TON of suspension to install.
![]() 93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc. 88 GT "Big Blue" - Body work & primer! |
#24 |
While UPR isn't quite as expensive as M&M or D&D, I believe they hold their own against anyone that is around the same price. And I've seen both M&M kits and UPR kits installed on cars and the only difference I see Is $$$$$.
#25 |
1993 Mustang LX Vert
I went ahead and purchased the control arms from UPR and installed them Saturday and it was well worth the time and effort, now just waiting on the 3.55 gears to get here from Summit and have them installed this weekend, hopefully the control arms will help put what power I have to the road!!!
#26 |
I ordered some lakwood tracton action lowers and upr uppers with moroso drag springs .I already have kyb shocks and struts.
#27 |
How do you like the KYB shocks and struts? are they adjustable? The reason I ask, I'm trying to decide between the $235, Tokico HP's (non adjustable) and the $390 KYB AGX (adjustable) Whats better in your opinion?
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer |
#28 |
I took of a set aof drag shocks and bought these agxs of my buddie and they work pretty good but i have yet to make a pass with them.Of coursed the ride is better along with the handling.
#29 | |
#30 | ||
I have the Eibach drag springs in the rear with Dugan racing upper and lower arms.. Hey Darrell what did you find out about the stock springs? You dont think the drag springs with the RR air bag works well?
#31 | |
No I don't. Team Z, Skinny Kid and Wolfe all told me the same thing. Run the stock GT springs and throw the drag springs in the garbage.
#32 |
El Conquistador
would it be a good idea just to upgrade the springs since my car is so old, i would like new ones but not lowering springs or anything, im trying to avoid lowering the car atleast right now i am, i have my traction bars but ill be occupied at pinks all out saturday in baytown so this weekend is a off weekend for the car
#33 | ||
Well looks like i will be doing a little test this season then.. I'll let you know what happens...
#34 |
ok so what are the things i need to do to be able to hook up on the street and at the track
im sure the upper and lower control arms, subframe connectors, and i guess ill leave the stock springs since darrel said they he has had people tell him they are better is there anything im missin would it be that much better to have adjustable u/l control arms |
#35 | |
Good adujustable shocks / struts will help. Depends how much you want to put in your suspension - complete overhaul, coil overs, or just enough to hook? |
#36 |
well the main thing im worried about is hooking up.......Right now i aint worried about making the ride more comfortable.
#37 |
If you just want to hook up better, get the control arms. If you spend a lot of time launching hard, look into the adjustables - but I may wait to do that a little bit longer on down the road once you see how the control arms help.
#38 | ||
#39 |
![]() Stock 5.0 Engine M/T Drag Radials E.T.- 13.859 MPH-97.23 60 foot-1.853 |
#40 | ||
Threads Similar to: Suspension and traction
| chassis,traction,suspension, and the like.... | matt0114 | General Tech | 13 | November 6th, 2007 04:09 PM |
| Traction help! | cammed281 | 99-04 | 6 | June 25th, 2007 09:12 AM |
| Traction....I need some | chase | 5.0 Mustangs | 6 | February 24th, 2007 11:38 PM |
| Traction | acehole | 99-04 | 11 | November 18th, 2006 09:01 PM |
| Traction | wagwjjr | General Tech | 6 | November 12th, 2006 10:32 AM |
