Suspension and traction - Page 3
Old September 14th, 2007, 08:03 PM   #41
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 89LX347
darrel what do you have on your car for rear suspension? i am making mine into a race car so i would like some imput i just installed tubular front suspension and 90/10 coilovers for the front
Team Z Motorsports upper control arms, offset lower control arms and anti roll device. I also have coil overs in the rear.
Old September 14th, 2007, 08:17 PM   #42
gotboost562's Avatar
gotboost562 is on a distinguished road
Send a message via AIM to gotboost562 Send a message via Yahoo to gotboost562
Are you running the upper control arms with the relocation brackets welded to the housing? Did you need to run the offset arms to clear the tire?
On another note- does anyone know if the GT and LX springs are the same or different? Anyone know the spring rates?
Old September 14th, 2007, 08:28 PM   #43
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The brackets are not welded to the housing. Team Z's kit uses a different method. I choose the offset lowers because I planned on running a 29.5x10.5W tire on the car.
Old September 14th, 2007, 08:34 PM   #44
With a 28x10.5W tire can you run the standard lower arms?
I thought with the relocation bracket on the uppers you were supposed to weld them in addition to using the bolt. Maybe that was another company.
Old September 14th, 2007, 08:43 PM   #45
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The 28x10.5W will fit without offset lowers but they won't fit without a mini tub. The relocation brackets bolt to the stock upper brackets on the housing and then are braced together and then a brace runs down to the front of the housing on each side.
Threads Similar to: Suspension and traction
chassis,traction,suspension, and the like.... matt0114 General Tech 13 November 6th, 2007 03:09 PM
Traction help! cammed281 99-04 6 June 25th, 2007 08:12 AM
Traction....I need some chase 5.0 Mustangs 6 February 24th, 2007 10:38 PM
Traction acehole 99-04 11 November 18th, 2006 08:01 PM
Traction wagwjjr General Tech 6 November 12th, 2006 09:32 AM
