DayLight Running Module-93 Fox
Where can i find the Daytime running light module on a 93 5.0.
I would like to disconnect it. P.S: I am in Canada |
Mine is right behind the middle of the dash behind the radio i have an 87 5.0
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
I have a 1993 notch. Are you talkin about the headlights? Mine are not on in the daytime... Am I misunderstanding something?
IS that true theres a daytime running lamp module in the old fox body Mustangs?
Mustangs I've owned... but never an SVT it's just my SN here... '88 5.0 LX 5 Speed '89 5.0 GT 5 Speed '87 4CYL Auto '95 5.0 GT AOD Vert. all else were hard tops. |
Its just a relay dont know why its their
No as far as I know they dont. I am the second owner of my car and I bought it from an old dude.. I know he did not mess with it. Did they even have them in 1993? I dont think so...
If there is a module for DRL's thats for the Canadian Mustangs, way before cars in the United States Had DRL''s Canadian cars had them first, so it would make sense that all Mustangs or Fords have a relay built in just in case it was sold in Canada. My friend had got a 92 Civic that was from Canada that had DRL's and we all know Hondas did not have that option in 92.
#8 | |
Moderator
![]() ![]() BUILD 2 IN PROGRESS |
ok cuz i knew we did not have them in those years. That other dude says he has it in his 87? They had them way back then too?
I guess Ford used one wiring harness for all Stangs, kind of like if you had a 87-93 LX , the fog light wires are tied up in the fenders, so you could add the fog lights if you wanted to fake up A GT, my LX had the wiring for fog lights...change the switch on the dash for both headlights and fog lamps. Does anyone else know about this?
Threads Similar to: DayLight Running Module-93 Fox
| control module | 92stang | 5.0 Mustangs | 0 | November 4th, 2007 09:35 PM |
| Windows Module Question.........? | gills99stang | 2005 - 2010 | 14 | July 27th, 2007 02:46 PM |
| Ignition control module | flynfalcon | V6 Mustangs | 6 | November 22nd, 2006 04:00 PM |
| Car Dies If It Is Too Hot Out - Ignition Module? | dr.gonzo! | 5.0 Mustangs | 11 | November 1st, 2006 10:26 PM |
| Prologixx Performance Module | jerb43 | General Tech | 0 | October 8th, 2006 09:36 PM |
