injector question
I found out today that my car has 36 lb injectors in it from the guy that had it before me.......In all my plans i was gona do 30 lb injectors and an MAF to match it with heads and cam and all that....
What i am asking is if i buy the MAF that is set for 30 lb injectors will the 36 lb ones work just as good since they are bigger or do i need precisely the 30 lb injectors to make it work right. |
You need 30lb calibrated MAF to run 30lb injectors. But if you have 36lb injectors and a matching MAF, why switch anything?
<<Why do people always think when a MAF says "calibrated for: XX" it's just jibberish that some lazy engineer scribbled on the side?>> |
ok i found a really good MAF......its the Pro-M like some people recomended and its 80 mm and im gona do a 75 mm TB so thats good and you get the exact one that you want....... injector size, supercharged, or N/A, and model of car.
now i can just keep the injectors i have and they will always be big enough since they are 36 lb now i just need the a pipe that can go from the MAF to the throttle body and will fit the 80mm.....any particular suggestions? http://www.jdsperformance.com/index.asp? initemuid=173&fcmd=item&inmake=0 |
Threads Similar to: injector question
| Injector Question... | haywood11 | 5.0 Mustangs | 10 | July 25th, 2008 04:04 PM |
| Just another Injector Question | dStoltenberg | 5.0 Mustangs | 11 | October 26th, 2007 01:10 AM |
| Another fuel injector question.. | One Bad Sixxx | V6 Mustangs | 48 | June 25th, 2007 07:47 AM |
| New car! And injector question. | Timothy_j | 5.0 Mustangs | 3 | May 17th, 2007 02:26 AM |
| injector question. | Slicey | 99-04 | 3 | April 10th, 2007 02:35 PM |
