Fiberglass bondo
Old March 8th, 2007, 11:14 AM   #1
Tr1gger is on a distinguished road
Fiberglass bondo'ing in my basement
Hey guys, a few weeks ago i posted about using bondo to fill a hole under hte driver seat while working in my basement. Everyone recommended getting cut and welded so it would be waterproof, but I have no way to get the car anywhere or to have anyone come here. Someone else mentioned Bondo fiberglass resin, and thats what I picked up. My question is, how would I go about using it. It says to spread a layer, lay down fiber glass, then spread another layer. Thats simple...but how would i spread it over the hole? Thanks.
Old March 8th, 2007, 01:36 PM   #2
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
Take a lil bit of chicken wire or get a sheet of the metal patchfill stuff where you got the bondo. Place it over the hole and commence to spreadin the stuff
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old March 8th, 2007, 02:40 PM   #3
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
you should actually have went & gotten a product called MAR-GLASS.. it's almost just like bondo but has fiberglass strands in it.. you should definately get this stuff, i know personally that it will fill that hole no problem.... get the hardener & spread it & mix it just like bondo... once it dries up sand it down a little & then re-apply another coat if necissary... you'll be good...
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old March 8th, 2007, 02:58 PM   #4
88BlueGT is on a distinguished road
Send a message via AIM to 88BlueGT
If your not trying to weld it you could get a piece of sheetmetal and screw it up from the bottom to cover the hole. Than use the fiberglass filler to harden everything. That will work, maybe not great but it will work. Why couldnt you have it cut & welded. You wouldnt get charged much at all. Is it non driveable?
93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc.
88 GT "Big Blue" - Body work & primer!
Old March 8th, 2007, 10:00 PM   #5
redalert89 is on a distinguished road
you need to go to your local collision repair shop and say hey bud how much $ do you want for a tube of liquid seam sealer, should run about 15 to 20 bucks there are adhesives that are stronger that any weld. be carefull this stuff comes in two tubes and once it is pushed through the mixing tubeit will be hard as a rock in a matter of seconds, just take a piece of sheet metal and lay it in there and apply it. dont drill any holes, thats just another place for it to leak! this is the way to go ive done this several times in jeeps
Old March 8th, 2007, 10:17 PM   #6
snaken's Avatar
snaken is on a distinguished road
I was at autozone yesterday and I saw that bondo actual made a stci kon metal grill just for that
Old March 8th, 2007, 10:28 PM   #7
homebrewed's Avatar
8.7 in the 1/8th
yup... The chicken wire is the cheap, redneck version of what you are taliking about
greatest band alive
:lickmynuts
Old March 11th, 2007, 12:04 PM   #8
Yea right now the car cannot be driven...it has no seats, or seat belts. I found this hole after pulling out the carpeting.
I have the fiberglass mat...dont I need to dip that in the bondo or something? I pretty lost on this. Bondo is simple...but using bondo with fiberglass mat and filing holes...im a little lost.
Would it be better to cover them fom under the car..or inside the car?
Old March 11th, 2007, 04:53 PM   #9
homebrewed's Avatar
8.7 in the 1/8th
Depend; hows your welding skills? Filling the hole is w/ bondo or fiberglass not the best, but its pretty cheap. Welding in a plate or using a metal filler w/ weld is more ideal.
The fiberglass is the exact same thing they use on Unique Whips to "make" their speaker boxes. It is the same principle as bondo, just a different chemical. It gets hard when it dries and can be sanded and painted. It will be fairly sturdy, but it will not be load bearing.
Fill the hole completely. Inside and out. Lessens the chance for moisture.
greatest band alive
:lickmynuts
Old March 11th, 2007, 04:56 PM   #10
homebrewed's Avatar
8.7 in the 1/8th
Resin is what you need. Fiberglass resin.
My bad
greatest band alive
:lickmynuts
Old March 15th, 2007, 06:58 AM   #11
zero is on a distinguished road
Send a message via AIM to zero
ok check this out. fiberglass does not adhere to metal. let me say that again for anyone who didnt hear.. fiberglass does not stick to metal. i should know, im an airframes mechanic on military aircraft. i agree with the metal and the screws (or rivets) if you try to layer on fiberglass over corroded metal or metal at all, it will seal up the hole untill the car starts to twist and bend as you drive. not too long after, the fiberglass will come apart and youll be back with a hole.
i dont mean to be rude, but do it right, or dont do it at all.
if you really have to use fiberglass on metal, like i have for my cowl hood.. use pop rivets (cherry max) and layer down sealant between the metal and the fiberglass. this means you have to impregnate and form the fiberglass FIRST. let it cure, sand all the excess resin off.. then drill your rivet holes putting something through the holes (klekos) to keep everything in place. you can do the same thing with a metal patch. if you want it to look professional in any manner, countersink the holes you drill and use countersunk rivets.. theyll sit flush with the patch, and you can sand it all smooth and primer and paint. no harm no foul and noones the wiser.
92 lx
351W w/ 60 overbore
holley 600cfm carb
weiand stealth dual plane intake
240/246@.510 cam
bbk long tube headders
msd coil
5 lug axle conversion
3.55 gears
mach1 style 17" rims
Old March 15th, 2007, 07:00 AM   #12
and id go with inside the car. that way if for some reason you spill something.. it doesnt collect in this low spot and if you use a metal patch, you can even use bondo to smooth out the bottom side and paint.
92 lx
351W w/ 60 overbore
holley 600cfm carb
240/246@.510 cam
msd coil
3.55 gears
Old March 15th, 2007, 09:07 PM   #13
I used the fiberglass jelly bondo with 2 sheets of fiberglass on the inside, and im gonna be using ultimate bondo under the car. I figure this should keep it pretty stiff, ill be priming and undercoating the car as well.
My question is, why wouldnt the fiberglass bondo hold under body flex if they make full cars out of fiberglass material? I figure with a few layers it should hold.
Old March 15th, 2007, 09:51 PM   #14
JBIGBOOTSY's Avatar
1990 LX hatch
My question is, why wouldnt the fiberglass bondo hold under body flex if they make full cars out of fiberglass material? I figure with a few layers it should hold.[/quote]
Because the body panels are made from large multi layered sheets. they are pressed so that all the exess resin is gone leaving a solid, ridgid ,stress dispursing panel. Using filler on a small hole is ok I bet it never pops out if done right.
Threads Similar to: Fiberglass bondo
Anyone with a fiberglass hatch? And then some 5.0 Mustangs 13 October 16th, 2007 10:33 AM
y2k fiberglass hood droppedbass87 Visual 5 May 2nd, 2007 02:55 AM
Fiberglass Hoods fastford3388 Visual 3 March 30th, 2007 12:59 AM
Bondo or not to bondo HELP! Tr1gger 5.0 Mustangs 9 February 26th, 2007 08:59 PM
Fiberglass Sub Box jerb43 Audio/Video 4 November 15th, 2006 11:05 AM
