Metal heater hoses alternative
LinkBack (1) Thread Tools
Old April 3rd, 2010, 07:16 PM   1 links from elsewhere to this Post. Click to view. #1
nolife's Avatar
91GT, 88GT, 02GT
Does anyone have any good ideas that I can use to get rid of the metal heater hoses over the lower intake. I still need the temp sensor (or move it if need be), cool the EGR, and supply my heater core though.
Old April 3rd, 2010, 08:47 PM   #2
1992 Lx
11.39@119.24
why do you want to get rid of them then dude?
Old April 3rd, 2010, 09:28 PM   #3
nolife's Avatar
91GT, 88GT, 02GT
Frustration I guess. They seem to be in the way all of the time. It's my own doing I guess because I still have everything... AC, EGR, smog pump, all of the TAD, and TAB emissions diverters and solenoid stuff, canister purge etc.. + the SC and its plumbing. If there is a decent alternative to using the metal pipes, I'd consider switching to it. Like I said, just venting I guess cause today they were in the way again and I picked up the wrong freaking heater hose as well. A simple job like lower intake gaskets that should take an hour or so ends up taking many hours because of interference removal and shit in the way. Okay, I'm done venting.
Old April 6th, 2010, 10:47 AM   #4
wizwrath is on a distinguished road
there is no simpler swap since you want to keep everything else, and the factory metal tube set up still keeps everything nicer then any other alternative.
Old April 6th, 2010, 10:55 AM   #5
I'd leave it alone unless you ditch allot or most of that stuff honestly plus they are getting hard to find and are fetching some godo prices used over on corral.net lately.
Old April 6th, 2010, 11:03 AM   #6
1992 Lx
11.39@119.24
Yeah I doubt it could take up any less room, ditch them and keep a jacket in your car
Old April 6th, 2010, 07:38 PM   #7
92twotone's Avatar
1992
12.0
92twotone is on a distinguished road
i beg to differ...I had to come up with an alternative solution to those metal heater hoses to clear my intake and fuel rails...I think that what I did looks pretty clean, and I don't see y someone couldnt do it just because they wanted to...I still had to use a small portion of the metal tube, the portion with the threaded end and sensor in it, however i cut the rest of the rails off, now the metal rails are replaced by some very flexible rubber hose purchased from the parker store...heres how it came out...pics arent the greatest but you get the idea.
http://hphotos-snc3.fbcdn.net/hs511...._7282506_n.jpg
overall they go pretty unnoticed in the engine compartment, and tuck nicely between the valve cover and manifold. let me know if you need any additional info or more detailed pics.
92gt,dark emerald green metallic/titanium silver two tone. canfields, jay allen custom grind cam, edelbrock super vic, power elbow and a buncha other crap
89 lx 5.0 hatch BONE stock
Old April 6th, 2010, 07:44 PM   #8
1989 LX coupe 5.0L
89lx is on a distinguished road
^^^^^^^^ different looking belt setup
Old April 6th, 2010, 07:50 PM   #9
92twotone's Avatar
1992
12.0
no ac, no smog, no tensioner underdrives...soon enough it will be no power steering either, then it'll be real short! lawn mower size haha
Old April 7th, 2010, 06:06 AM   #10
1989 LX coupe 5.0L
i have no a/c, no smog, and a march alt bracket , plus underdrives and my belt goes from the ps pump to the alt across the top
Old April 7th, 2010, 10:33 AM   #11
Why? You running a standard rotation waterpump rather then the stock type counter clock wise or reverse rotation waterpump?
Old April 7th, 2010, 11:40 AM   #12
Proud American
MustangMatt96GT's Avatar
From the way his belt is run it looks like a reverse rotation... which is what he needs is it not, if his pump is stock? I have a forward rotation on my engine though.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 7th, 2010, 11:50 AM   #13
92twotone's Avatar
1992
12.0
my belt is run the only way it can be with this setup...stock reverse rotation wp. when i get rid of my power steering i will have to change to a forward rotation wp off of like an 85 crown vic or somethin.
i wanna know what the op is thinkin bout the heater tubes though, enough talk bout belts
Old April 7th, 2010, 12:04 PM   #14
You don't have to change to a standard rotation pump if you are using an electric fan just use a shorter belt like I have been using for three years now on my turbo car. Here's an old pic allot has changed since but the belt routing is still the same.
http://i571.photobucket.com/albums/s...T/61e7ba6f.jpg
Old April 7th, 2010, 12:11 PM   #15
Proud American
While this is true, i would steer away from it... reason being is with it wrapped around on a standard rotation like mine (pic), you have nearly 1/4 of the belt touching the pully for rotating power... the way you have it, you have barely an 1/8... thats the way I looked at it and decided against going reverse rotation for that reason.
Sorry for the thread jack...
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 7th, 2010, 08:28 PM   #16
Uber88GT's Avatar
1988 Mustang GT
Uber88GT is on a distinguished road
I plan on routing my heater hoses on top of my valve cover, as my sensor won't clear the fuel rails, not as nice as the above example, and kinda chevy style, but having a heater was the only stipulation the old lady had for me spending thousands:
Old April 7th, 2010, 10:45 PM   #17
Originally Posted by MustangMatt96GT View Post
While this is true, i would steer away from it... reason being is with it wrapped around on a standard rotation like mine (pic), you have nearly 1/4 of the belt touching the pully for rotating power... the way you have it, you have barely an 1/8... thats the way I looked at it and decided against going reverse rotation for that reason..
although a valid point, it's enough contact because I haven't had issues with it in years of use. I also have my syclone setup the same way without issue. If you have the mechanical fan still though then you'll have slippage and I wouldn't recommend my way.
Old April 8th, 2010, 11:37 AM   #18
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
my belt set up.
uses the stock placement of the power steering with the A/C, but a/c is gone now. used a alternator bracket as the tensor, and hung it extra low for a clean look, and to make the heads the focal point of the hole motor.
BEFORE (previous owner went crazy with chrome and blue wire loom)
now after hiding wires, pulling a/c and emissions, and the new accessories set up.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old April 8th, 2010, 01:10 PM   #19
1992 Lx
11.39@119.24
Howd you paint your cai? Spray paint? it looks good
Old April 8th, 2010, 02:21 PM   #20
302Army187's Avatar
'89 LX 'Vert
nah, totally different CAI. Its from "stack racing" got it on american muscle.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/159736-metal-heater-hoses-alternative.html
bad experience with AM - Page 2 - Ford Mustang Forums This thread Refback August 31st, 2010 10:57 AM
Threads Similar to: Metal heater hoses alternative
Nitto NT555 Alternative Redfire66 2005 - 2010 21 March 31st, 2010 08:16 AM
HELP! Cannot Attach Heater Core Hoses... jrobinsonchicago 99-04 13 August 23rd, 2009 05:48 PM
Alternative to NGK TR6 plugs...Misfire!! BakerFX4 99-04 35 June 23rd, 2008 10:15 PM
Tuner Alternative? JOHNNY K. 99-04 6 May 7th, 2008 02:37 PM
heater hoses on the tb 92lxhatch 5.0 Mustangs 2 February 1st, 2008 09:12 AM
