#1 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Compression?
What Compression will I have when I install my TFS 51400004 heads with a 61cc Chamber and stock pistons (95 5.0) ??
Trick Flow Specialties TFS-51400004 - Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford - Overview - SummitRacing.com ^^For reference. Tim
Military Crew USMC
1990 LX hatch
what head gaskets? And is the block un decked?
#3 | ||
The block isnt decked and the head gaskets that are with the Trick flow kit.
Military Crew USMC
#4 | ||
Trick Flow Specialties TFS-51400904 - Trick Flow® Full Gasket Sets - Overview - SummitRacing.com
These gaskets... does anyone have an idea on the compression I will have?
Military Crew USMC
1990 LX hatch
i cant find the thickness of the gaskets, but if they are close to .040" about 9.2:1
#6 | ||
I will measure and see when I get em, I thought it would be lower then that so I am haooy with 9.2:1 is that good?
Military Crew USMC
1991 Mustang LX 5.0
Stock is 9:1 so you will be slightly better without having to worry about octane levels. Also you are still well within safe limits for moderate boost if you ever decide to go that route.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: Compression?
| compression 9 to 1 VS. 11 to 1 | ryanw | 5.0 Mustangs | 6 | November 13th, 2010 09:18 AM |
| 9:1 compression 4v? | Boostang | 99-04 | 9 | October 5th, 2009 12:18 AM |
| pi compression | ModularSteed | 96-98 | 12 | July 12th, 2009 11:49 PM |
| How much compression? | bossman69 | Classic Mustangs | 2 | October 6th, 2008 07:59 PM |
| compression? | matfernan1 | 99-04 | 5 | August 30th, 2007 11:42 PM |
