Discussing B303 cam in the 5.0 Mustangs Forum. If there is already a topic that discusses this, cool, I'll look deeper. Anyway, ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Editor
'88 LX body '91 GT D/T
8.7 in the 1/8th
B303 camAnyway, my car has the B303 cam. What does that mean? What are some of the specs? Lift, duration, overlap, etc. I did some looking online, and found lots of stuff on the "E" & "F" cams, but nothing on my B. Thanks!
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
How did you not find this? It's the first result for "b303 cam"
http://www.fordracingparts.com/parts...rtKeyField=899 |
Editor
8.7 in the 1/8th
Cause I am too impatient and am from Missouri... We kinda s s s slow out here
Thanks!!
Editor
8.7 in the 1/8th
What do those numbers mean? I am a chassis tuner. Suspension, brakes, weight transfer, etc. are my forte'. I don't really know how to interpert the # of a cam or its profile
ur valves stay open 13 degrees longer on the intake side and closes 42 degrees sooner more air equals more power.It basically closes the valves quicker although the lift is mild . the cam has a closer overlap which gives it a rougher idle. some one correct me if im wrong its been a while
Well what do you want to know exactly? Just an explicit description of .498"/.498" @ 282*/282* ?
Here's a good place to start http://www.streetracersonline.com/articles/camshafts/ |
Editor
8.7 in the 1/8th
Sweet link!! Thanks
what part of kc you from?
FREE LUNCH, FINAL WISDOM, TOTAL COVERAGE... WHY NOT?
Editor
8.7 in the 1/8th
Grandview woot woot!! Yeah, no not so much. I wanna move to PV Kansas or maybe Leawood.
How bout you doc? I bet we know some of the same people.
ha! belton. I bet you have seen the dragon kia
Editor
8.7 in the 1/8th
Not yet. I just moved there recently.
I got a buddy back home that met a chic thru myspace from belton lol
I found out the trick is to live in mo and work in ks (cheaper gas, cheaper ho...well cheaper everything.) gas went up like 10cents a gallon across that line
Editor
8.7 in the 1/8th
I have lived in MO way too long. Hell, the midwest for that matter. Where you work@?
I was canned from jcpenny on lackman rd in ks and that job really blew but it was good money, so now I land survey in belton, lots of free time and im outside.
Editor
8.7 in the 1/8th
How long you been in the Mustang circle? You know shedvil from KS? Or venmous?
You on that retarded KCSR?
mabey about a year but I really dont know anyone around here. my car only ran a 14.9 so untill I can get that down to atleast low 13's im not going to go race anytime soon. it sucks being the slowest mustang at the track. at lesast there was a late 80's camaro running mid 15's. yep im on kcsr 88stanggt my cousin put a "brace yourself, honda tuning" licens plate frame on my car off of his acura intg h22 so people always try to race me. that h22 would whip me...if it would run right lol
Editor
8.7 in the 1/8th
Heheh... Well, shedvil is my ex and she does more street cruisin than track as of late. Why is your GT only hittin the hi 14's? Take out a seat or the spare tire or something Damn... Is it sick? Need to see the "Doctor"? Oh, thats you... What gives?
its a fear and loathing (movie) name. I think it was a traction issue. I burned out on street tires and they might of held water in the groove and I had a helmet on and couldnt tell I was buring out off the line. I took out the sub woofer system but I was drivng the car to the track and I know my luck. if I would have taken the spare out I would have needed it.
it needs a tune up and new back tires, all the fluids changed. just been wating for that weekend combo of enough money and 70 degrees. my car seems to take off great but after 50 mph limp as bob dole. new fuel filter/pump pressure? I am going to try that sea foam engine cleaner stuff to see if it helps any.
Editor
8.7 in the 1/8th
NO!!!!!!!!! Do NOT use seafoam!!! Use some B-12 Chem tool. The seafoam has oil in it. The Chem tool will clean much better and is cheaper. I have used both and will NOT use anything but the B-12.
As far as workin on your car, the fluids are cheap and easy to do. The rear diff can be a bitch, but but it can be done inside of 90minutes. Gimme a shout sometime. (816)596-1562 (cell) I'll give ya a hand. I got a few buddies that work @ Advance and Oreilly auto. I'll get ya the hook-up
I found this
1988 Ford Mustang GT 6.4 15.0 stock 1/4 mile time. so with the convertable weight about 15.3 stock then I bought it with 3.73 gears and I think a valve body shift kit. im guessing that how I get 14.9. I have the aod so I will see how 4.10s do.
Threads Similar to: B303 cam
| B303 Cam | acmillr | 5.0 Mustangs | 32 | November 9th, 2007 09:10 PM |
| B303 or E303?? | 92mustanglx | 5.0 Mustangs | 13 | May 29th, 2007 06:38 PM |
| b303 cam with 1.72rr's | bigbadtalontsi | 5.0 Mustangs | 5 | January 16th, 2007 06:36 PM |
