Discussing S/C questions in the 5.0 Mustangs Forum. well first off ide like to know the best S/C i can get for ...
Old March 9th, 2007, 10:32 AM   #1
S/C questions
well first off ide like to know the best S/C i can get for my 95 cobra. and then also i know it is safe to run 8-10 but what about like 15? on stock bottom? what kind of dyno numbers do you guys think i could see (h-pipes, no cats shorty headers) any input is really appreciated i dont know much about S/C's so i need fuel for thought. i know im going to spend some dough. im prepared to spend about 4500, but i want my 4500 worth of performance on stock bottom. and i want a S/C that i can crank more boost out of in the future when i upgrade the bottom. but for now i rreally want to see at least 100 extra ponys. and i am already aware that ill need to get the car dyno tuned. so anyone know of a good tune shop in PNW? thanks once again guys!
94 cobra, headers, CAI, h-pipes, flowy 40 series, short throw, underdrive pulleys, 3.73's
Old March 9th, 2007, 11:31 AM   #2
the guys at 5.0 mustang successfully added 17psi of boost with a vortech SQ with a AFM B31 cam Trickflow TW heads PP typhoon intake 75mm tbody lightning mass air meter and 50lb injectors. Im not sure on the pump or whether they used a FMU but they made 506hp with a stock bottom end. They did this with the factory forged pistons which im not sure your engine has. I think 92 was the last year they came factory
Speed kills drive an import and live forever.
1991 LX 5.0 H/B
1990 T-BIRD SC
Old March 9th, 2007, 03:04 PM   #3
there seems to be alot of potential for my car with heads and a cam plus S/C. i was looking at the novi2000 but i have heard some good things on the vortech.
Old March 9th, 2007, 04:14 PM   #4
Editor
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
Are you wanting a centrifugal or roots style? A cetri. will spool kinda like a turbo. ie; higher RPM. A roots will be a flatter, lower RPM power source.
IMO, go ProCharger. Yeah, yeah, I say that alot, but they are local for me (Lenexa KS) and I have seen what they are capable of. Crazy power!
A D-1SC is upgradable. No oil lines, self contained oiling system, highest PRM's for the impeller, super easy install,
www.procharger.com
(913)338-2886
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old March 9th, 2007, 09:43 PM   #5
Kenne bell came out with a new big bore supercharger that just takes the place of the intake.it will help you out in the low and midrange which is good for a street car
1991 LX 5.0 H/B
1990 T-BIRD SC
Old March 9th, 2007, 09:55 PM   #6
Stangzilla's Avatar
I disagree I think the centrifuge type is better because a Mustang already has a good amount of low end and by having the boost come on mid to top helps the car already have traction when the boost comes on. With a roots type boost comes on pretty much off idle and does not help the traction on take-off. Even with a good suspension on a Mustang when you have 400+RWHP try and get a good launch on the street with that...
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old March 9th, 2007, 10:02 PM   #7
WilltheThrill's Avatar
03 Cobra
13.2 @ 108 at 2710 ft. elevation
if your car is gonna be a daily driver, I recommend that u run low or moderate boost on that stock non forged engine, 15 psi would be too risky. Now if u have alot of play money, and an extra vehicle, then go ahead and run 12-15 psi. Your engine would handle it for a while but there would be a high chance of breakin a rod or somethin.
03 cobra:soon to be pullied/tuned by Greg @ RET-clutch-Xpipe-flows w/3" piping out back-adj. clutch cable with quadrant-BBK firewall adjuster
91 prelude: CAI-full exhaust-clutch-Eibach lowering springs
Old March 9th, 2007, 10:04 PM   #8
Stangzilla's Avatar
+172176283272792
Old March 9th, 2007, 10:05 PM   #9
Stangzilla's Avatar
10psi max safely....Good tune of course...
Old March 9th, 2007, 10:15 PM   #10
Editor
homebrewed's Avatar
8.7 in the 1/8th
+ like a bunch^ on the last 2 posts!!
greatest band alive
:lickmynuts
Old March 9th, 2007, 10:33 PM   #11
Stangzilla's Avatar
Oh forgot to mention the great amount of stress a Roots style charger puts on the front of your crankshaft.. Especially when the belt is real tight for max boost.. Stock motors dont like to have their crank pulled!!! hahahalol get it!!! hahahaa
Old March 9th, 2007, 10:35 PM   #12
Editor
homebrewed's Avatar
8.7 in the 1/8th
And the cheese :award goes to.... STANGZILLA!!!!!!
J/K bro. Excellent point
greatest band alive
:lickmynuts
Old March 9th, 2007, 10:56 PM   #13
03 Cobra
hmmm....I should check the tightness of my belt
Old March 9th, 2007, 11:08 PM   #14
Stangzilla why would ford use a roots style if that was such an issue.
1991 LX 5.0 H/B
1990 T-BIRD SC
Old March 9th, 2007, 11:11 PM   #15
Would a $150000 ford gt have one if that was a problem ? No
1991 LX 5.0 H/B
1990 T-BIRD SC
Old March 9th, 2007, 11:12 PM   #16
Stangzilla's Avatar
It is not an issue on a car that came with a Roots style blower but it can be an issue if you just bolt one on... Not sayin its gonna kill your motor or anything but its just another thing to think about when pickin out a S/C
Old March 9th, 2007, 11:14 PM   #17
Stangzilla's Avatar
Dude chill
Threads Similar to: S/C questions
Few Questions Bies08 V6 Mustangs 12 August 21st, 2007 10:33 PM
rim questions SilverGT04 99-04 26 August 17th, 2007 01:54 AM
*a few questions* mustang1072 V6 Mustangs 10 June 28th, 2007 11:59 PM
Questions about new car! Blown93Cobra 5.0 Mustangs 6 June 4th, 2007 03:45 PM
2 Questions mikethetigerrr V6 Mustangs 21 October 25th, 2006 09:23 AM
