replacing stock 302 heads with windsor 351 heads - questions - Forums at Modded Mustangs
post #1 of 6 Old April 13th, 2010, 01:28 AM Thread Starter
Tootheroots
Hey everyone-
My son and I are in the process of replacing the heads on a 302 5.0 . He bought the car specifically for the engine (It has cracked head or blown gasket) according to the previous owner. Well, we found some 351 Windsor Heads to replace the stock 302 heads. We have the engine torn down - (still in the car) , removed the intake and old heads, and in the process of scraping off old head gaskets / cleaning surface. We are wantjng to replace intake now and wondering if you all have any suggestions as far as what intake?
Tootheroots is offline
post #2 of 6 Old April 13th, 2010, 10:21 AM
Vic JR. or weiand Axcelrator
McMustang5.0 is offline
post #3 of 6 Old April 13th, 2010, 10:53 AM
Priest of the Car Gods
ReverendDexter's Avatar
Is this a fuel injected or carbureted motor you're building? Is this a daily driver or a track beast? And what sort of RPM are you shooting for?
Function > Form, always
ReverendDexter is offline
post #4 of 6 Old April 14th, 2010, 08:54 PM Thread Starter
Tootheroots
well its carburated its pretty much stock and i was wanting to get my rpms around 5,800 or 6,000. its going into a 65 mustang that will be a daily driver but i do want to take it to the track every know and then.
post #5 of 6 Old April 15th, 2010, 01:39 AM
get either the edelbrock air gap or the summit brand air gap summits a little cheaper and i have one on my motor and its great im making about 300hp to the wheels with stock heads on a 331
foxcobra262 is offline
post #6 of 6 Old April 15th, 2010, 10:51 AM
Based on that, I would stick with a decent, name brand dual-plenum intake that's good for the idle-5500 rpm range. If you start moving your rpm up, say to a 1500-6500 rpm peice, you're gonna lose a little low-end drivability/economy that's pretty important for a DD. Now, admittedly, I'm not sure how pairing a 1500-6500rpm intake with a stock cam is going to react, I'm guessing you'd just lose a little low-end.
Human Verification
