Heads
Old March 10th, 2007, 01:04 AM   #1
427fox is on a distinguished road
Heads
I would like to know what heads all of the mustang fans are runing I'm runing AFR205s
I love to talk about mustangs all years always wanting to learn something new.
Old March 10th, 2007, 08:40 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'm running Trick Flow CNC225 R-series heads.
Old March 10th, 2007, 10:57 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Re: Heads
What else do you have in your car besides heads?
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 11th, 2007, 09:42 PM   #4
351 storked to a 427, 588 lift cam,250 shot,afr 205 stage 3 heads AED carb, long tube step headers, flowmaster 1 chambers. The bottom end is by DSS a XR short block with the main support system. A 373 gear with a 5sp, coil overs 90/10 front,50/50 rear, dot slicks on weld draglites, subframe connectors, 10 point cage. Electric water pump also on the motor,in the rear also mega bite jrs.
Old March 11th, 2007, 09:43 PM   #5
Stock E7s baby, only for a little longer though!
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old March 11th, 2007, 09:44 PM   #6
sb2f5marine69's Avatar
sb2f5marine69 is on a distinguished road
smae here only for a little while longer
Old March 11th, 2007, 09:48 PM   #7
what are you thinking about geting
Old March 11th, 2007, 09:58 PM   #8
tfs heads all the way. tfs tacke heat 170 's with a mild port job from my buddys machine shop.
Old March 11th, 2007, 09:58 PM   #9
sorry track heat
Old March 11th, 2007, 10:25 PM   #10
IcantDo55 is on a distinguished road
I also have AFR205's
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old March 11th, 2007, 10:31 PM   #11
Stangzilla's Avatar
I run AFR 185's on my 347..
Old March 11th, 2007, 10:32 PM   #12
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
AFR 165s here
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old March 11th, 2007, 10:34 PM   #13
http://store.summitracing.com/partde...&view=1&N=700+
Plus a SCAT 347 kit
[SIGPIC][/SIGPIC]
Threads Similar to: Heads
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 10:01 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 10:34 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 10:55 PM
289 Heads ezra27 General Tech 0 December 31st, 2006 12:09 AM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 04:18 PM
