Car Missing Out
Old March 10th, 2007, 03:02 AM   #1
bigbadtalontsi is on a distinguished road
Car Missing Out
So here's the situation. When i pull my car to redline and shift hard the car starts to miss out. It feels like a dead plug or injector. The car will miss for about 1 minute then pull itself out of it. Any suggestions? My mod list consists of GT40 heads, GT40 intake,Under Drives,B303w1.72rrs,BBK headers,73mm MAFS,CAI,Catless H-PipewFlows,Timing Advanced. I probably forgot a few. Can anyone tell me an estimated horsepower number? All replys will be appreciated
Old March 10th, 2007, 02:28 PM   #2
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
If its cutting out @ redline (Where is your redline?) your ingition is having trouble firing the plugs.
What year is your car? Do you have an ignition upgrade on it? If so, what type? Try testing your coil @ a parts store. Are your ingition cables(wires) shorting out? Crossing a ground?
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old March 10th, 2007, 09:52 PM   #3
Redline is 5500. Ignition is stock. The car will also rev itself up. It will be idleing fine then all the sudden jump 750-1000 rpms and stay there for a few seconds.
Old March 10th, 2007, 10:06 PM   #4
homebrewed's Avatar
8.7 in the 1/8th
Try unpluggin the IAC (on the throttle body) and see if it(the idle) smooths out. If so, odds are its bad. Possibly the MAF or TPS.
TT86 had a problem similiar to this, I think. No quoting tho.
greatest band alive
:lickmynuts
Old March 10th, 2007, 10:54 PM   #5
Stangzilla's Avatar
Stangzilla is on a distinguished road
Yeah redline is 5500 but if I remember correctly the rev limiter kicks in at 6250rpm? I have a PMS and mine is set at 6700rpm..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 10th, 2007, 10:58 PM   #6
homebrewed's Avatar
8.7 in the 1/8th
Heheh... Mine don't have all that. It'll twist till I let my foot off the gas. I got my shift light @6700 tho.
Need to get an MDS or something...
greatest band alive
:lickmynuts
Old March 10th, 2007, 11:10 PM   #7
Stangzilla's Avatar
Whats an MSD gonna do? If you have an MSD box and say you put a 6500rpm chip in there, I dont think it's gonna change the rev limit. That function is in the computer and you need something to bypass that.. Like a PMS or a rev limit extender...
Old March 10th, 2007, 11:15 PM   #8
homebrewed's Avatar
8.7 in the 1/8th
The 6al and its program pills WON'T act as a revlimiter?
Hmmm... I have been misinformed then. Thank you
greatest band alive
:lickmynuts
Old March 10th, 2007, 11:40 PM   #9
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
The pills will cut spark at the desired rpm, but the factory rev limiter needs to be turned of in the pcm if you plan on taking it past 6250. The factory rev limiter cuts the fuel not spark.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old March 10th, 2007, 11:44 PM   #10
homebrewed's Avatar
8.7 in the 1/8th
It will wind ALL the way out. Evidently, that lil diddy has already been removed.
My car is a 5.0 conv. done before I bought it from my buddy. Started out as a 2.3
greatest band alive
:lickmynuts
Old March 11th, 2007, 05:47 PM   #11
goodyear1984 is on a distinguished road
if its reving up and down the iac is proll bad but u can clean it and try it...also get some maf cleaner to clean the maf or some kinda electronic cleaner ...dont use and carb cleaner as it will damage the sensor
Threads Similar to: Car Missing Out
97 V6 missing on cyl 4,5,and 6 a_calm_victim V6 Mustangs 10 July 5th, 2007 08:48 AM
What is the Mustangs missing ? EmmaG Modular Mustangs 24 July 1st, 2007 08:05 PM
Engine missing Q's Rutcutter 5.0 Mustangs 21 June 4th, 2007 06:05 PM
Random missing nolife 5.0 Mustangs 8 May 6th, 2007 07:55 PM
Car Missing Out Bad bigbadtalontsi 5.0 Mustangs 7 March 28th, 2007 06:14 AM
