1986 5.0 Loss of power above 2500 RPM , and backfire
Old March 10th, 2007, 01:41 PM   #1
Look Ma! My First Post!
86-5.0 is on a distinguished road
Hey everyone, hopefully someone could help shed some light on this for me, Car runs into a dead spot (only with a load on) above 2500 rpm, begins to backfire periodicly. Fireing order ok, no vacum leaks..cannot see any leaky injectors, I swapped the TPS but no change. I also pulled the spout connector for the advance and drove it but no change, I have no residual pressure at the schrader valve when the engine is off. Any help would be appreciated..
Old March 10th, 2007, 01:46 PM   #2
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well you should have pressure in that valve when the car shuts down.. You should be able to push that pin and fuel should squirt out pretty good.. I would suspect the fuel pump.. Its in the gas tank if you dont know where it is.. And make sure you spend the few extra $$ it costs and put a 255lph pump in there. It will leave you room to grow and you wont have to take the tank out again to upgrade down the road..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Threads Similar to: 1986 5.0 Loss of power above 2500 RPM , and backfire
Could This Cause Loss Of Power VSR13 V6 Mustangs 24 December 14th, 2007 11:08 AM
Loss Of Power! Help Please! alamo11 V6 Mustangs 8 December 14th, 2007 09:34 AM
power loss? xedubx 99-04 16 June 20th, 2007 10:52 PM
Loss of low end power ByPopularDemand V6 Mustangs 24 May 10th, 2007 10:00 PM
Power Loss the hammr 5.0 Mustangs 8 August 17th, 2006 09:48 PM
