what are some good cheap power adders i can put on my car? - Forums at Modded Mustangs
post #1 of 14 Old April 22nd, 2010, 02:28 AM Thread Starter
i have a 95 mustang gt 5.0 auto, with 3.73 gears b&m shift kit bbk underdrive pullys, cold air intake with k&n filter, sct chip, msd blaster coil, nitrous express 75 shot, hooker headers off road h pipe with 40 series flow masters, i wanna get some more power with cheap power adders i haven't hit the nitrous yet but i wanna hear some opinions if anyone has some parts for sale Lmk thanks kyle
kyleboyd is offline
post #2 of 14 Old April 22nd, 2010, 03:44 AM
e3sean's Avatar
hit the nitrous its the cheapest poweradder there is (short term)
<font size=4><b>MILITARY CREW
e3sean is offline
post #3 of 14 Old April 22nd, 2010, 03:45 AM
Admanistrator
v606er's Avatar
Nitrous, supercharger, turbocharger, and turbonator!
MAD Stangs #8
v606er is offline
post #4 of 14 Old April 22nd, 2010, 03:47 AM
Garrett's Avatar
Send a message via AIM to Garrett
^ I thought he said cheap...I must of missed read something
myspace.com/garrettstarnes
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
Throtle Body spacer.
More to come!
Garrett is offline
post #5 of 14 Old April 22nd, 2010, 11:21 AM
BORDEN's Avatar
get a set of aftermarket heads and keep the bottle on it
BORDEN is offline
post #6 of 14 Old April 22nd, 2010, 05:18 PM
Timm10221's Avatar
Your ready for heads and cam swap, and then a good mass air meter calibrated from 24# injectors and get some 24 pounders... Other then that... change out for a 100 shot or 125
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Timm10221 is offline
post #7 of 14 Old April 22nd, 2010, 05:20 PM Thread Starter
i heard of some ppl putting the 98 explorer/ mountaineer 5.0 gt40p heads and intake on them does that help alot? what about a throttle body? and what size of a throttle body?
kyleboyd is offline
post #8 of 14 Old April 22nd, 2010, 05:26 PM
Timm10221's Avatar
the combo from what I hear is good for 30rwhp and I would run a 70mm TB no bigger... That would be a good budget build man...
Military Crew USMC
post #9 of 14 Old April 22nd, 2010, 05:36 PM Thread Starter
thanks for the all the help. i was thinking about putting a cam in to because my front main is starting to leak and i am gonna change it but i was gonna put a cam in at the same time what cam would you suggest? i see alot of people saying they have the x303 or the e303 cam? and do you think a 3600 stall would help or make the car slower? because its really doggy form the line until it gets up to rpms
kyleboyd is offline
post #10 of 14 Old April 22nd, 2010, 06:48 PM
Burn'nRubber's Avatar
unless you upgrade your heads, I wouldnt look into any aftermarket camshaft. If you do upgrade your heads and/or decide to get a cam I would stay away from the alphabet cams as there are much better options out there.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
1995 Cobra roller: in progress
Burn'nRubber is offline
post #11 of 14 Old April 22nd, 2010, 06:57 PM
Timm10221's Avatar
+1 Dont get a letter cam go trickflow or anderson motorsports, 3600 is way to much stall for your app, a 2800-3000 would work, I have a stage 2 cam and Need a high stall and I am only going with a 3200... stock to mild cam doesnt need or could benifit from a 3600 but a 3000 are would help. You kinda wanna lock up right where your making good power not way after the fact...
Military Crew USMC
post #12 of 14 Old April 22nd, 2010, 09:12 PM
If you really want really cheap mods.
weight reduction.
a light car goes faster, simple.
alot of people would disagree, but its pure science and physics.
but with your setup, i would probably go with a Stall converter.
those aods suck. probably a 3200 max.
you could always swap over GT40 heads and a #cam easy
i would stray from the # cams though. maybe, like Timm said, an andersen # or trickflow cam
StckFox is offline
post #13 of 14 Old April 23rd, 2010, 04:46 AM Thread Starter
thanks for all the info. Now as for the stall any brands to stay away from?
kyleboyd is offline
post #14 of 14 Old April 23rd, 2010, 04:55 AM Thread Starter
i have heard the aodes are junk i wanna change mine to 5 speed but i don't have the money for all that ( flywheel, flywheel bolts, clutch kit, t5 trans, pedal assembly, 5 speed ecu/ wiring for trans, clutch cable, 5 speed cross member, 5 speed drive shaft, and what ever else i am missing, if someone had a parts car with all that for cheap that would be awesome but i cant find one
kyleboyd is offline
Human Verification
