smog pump help
im putting a 331 with trick flows in i wana remove the smog pump but keep the egr stuff i have emissions where im at its all apart right now do i need to plug up any lines on the smog stuff and will i get a code with out the air pump stuff on
1990 LX hatch
no codes as long as the EGRs plugged in, The only thing you have to do for the smog pump is to fill the holes in the heads for the smog tubes, I just made little plates out of steel using the smog tubes as a templateand bolted them on.
new motor
will the car run ok for break in after i put in all new motor fuel heads cam dist all off it i bought all new stuff i know ill need dyno but will my comp freak out its a 1994
Threads Similar to: smog pump help
| smog pump | skid6 | 5.0 Mustangs | 4 | October 9th, 2007 09:06 PM |
| smog pump | cali 5.0 | Modular Mustangs | 0 | April 21st, 2007 01:08 AM |
| Smog Pump | jcc1991 | 5.0 Mustangs | 3 | September 4th, 2006 12:51 PM |
| smog pump | cali 5.0 | 5.0 Mustangs | 3 | July 24th, 2006 02:03 PM |
