Motor hesitation?
Old March 11th, 2007, 09:59 PM   #1
gregkelley is on a distinguished road
Motor hesitation?
I just bought a 5.0 and it has been converted to a carb and if I punch the throttle down it hesitates and then takes off the carb is set how it came stock and is brand new not many miles can anyone help here is what I have on the motor. 650 Holly carb ,eldebrock victor jr intake, msd distributor, after market plug wires, and a cam not sure what kind but know it is not stock and the motor is gear driven. As far as I know everything else is stock. Please help it is driving me crazy.
Old March 11th, 2007, 11:51 PM   #2
SALIV8's Avatar
SALIV8 is on a distinguished road
Re: Motor hesitation?
Sounds like it may be a bad accelerator pump or many other issues. I would check pump ops first. to check ops shut engine off remove air cleaner, open and close throttle while looking into carb air horn, and you should see a stream of fuel spray into air horn, it should start as soon as you open the throttle. It shuld continue for a bit after full throttle. if the fuel is weak adjust/repair pump.
Threads Similar to: Motor hesitation?
Hesitation gotime89 5.0 Mustangs 11 October 12th, 2007 10:24 PM
hesitation? CBSTANG 99-04 5 July 26th, 2007 08:57 PM
hesitation usmcsawgunner 5.0 Mustangs 9 July 10th, 2007 09:58 PM
Hesitation? 97gtstang 96-98 2 April 16th, 2007 04:56 PM
Please Help! (Hesitation) das50cal 2005 - 2010 4 September 10th, 2006 10:44 PM
