Anything else needed to support a Supercharger?
I just bought a Paxton Novi supercharger and plan to run it at 9 PSI. Is there any way to tell if I will need fuel/ignition upgrades ahead of time, or should I take it to a tuner then decide? I am still building the car, so I was hoping to have everything ready to go when I take it to the tuner.
Here are my mods: 5.0 HO out of a 91 Mild Lunati Cam (similar specs to Ford E cam) Ported and Polished GT40p heads and intake 70mm throttle body MSD Blaster Coil MAC shorty headers BBK Hi-Flow Cat H-Pipe Magnaflow CatBack MAC Underdrive Pulleys I plan on getting an in tank 255 LPH fuel pump, anything else I should do? Also, I don't have a tuner picked out yet, so if anyone has recommendations near Cleveland, Ohio, let me know. Thanks
Current Mustangs: 2004 Cobra Convertible 1993 5.0 LX Hatchback 1992 5.0 LX Convertible |
For my Kenne Bell @ 9psi it was recommended to swap to 42# injectors, a 90mm MAF from a Lightning and have a tune.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
go with sniper tuning my buddy has ran it on his stang for a while now and sniper can walk u through the tuning process to give u a base line before you spend 2 hours on a dyno. check it out
www.snipertuning.com |
Definitely get an aftermarket fuel pressure regulator so you can tune your fuel. Might wanna think about upgrading to an aftermarket radiatorand higher flowing water pump too since your motor will be running at higher temps on the boost. I bought a Fluidyne last year and think it was money well spent for my Stroker application...
Injectors
Boost Gauge AFPR A/F Gauge etc.
![]() 93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc. 88 GT "Big Blue" - Body work & primer! |
I forgot to put it up in the list, but I do have an aftermarket fuel pressure regulator already. I have an electric fuel pressure gauge. I have been looking at a A/F ratio gauge, but I have read alot of bad things about the narrow band, and haven't felt like springing for the wideband yet... With a good tune is the A/F gauge necessary? I guess if there was a problem and it saves me from blowing up the engine it would be money well spent.
Would you recommend that I buy 42 pound injectors and the lightning 90mm MAF now, or would that be subject to change, depending on how things come out on the dyno? Thats a good tip on the radiator and waterpump. My radiator looks like terrible, so I was planning on buying a new one anyways.
You should also get an inline booster pump like a T-Rex or something like that..
'88 LX body '91 GT D/T
8.7 in the 1/8th
Wideband/UEGO
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#9 | |
8.7 in the 1/8th
Thank you
I would say that the wideband is a must but others might disagree. Even if you have a good tune remember unless its done on a Mustang dyno it does not simulate road conditions. Every day is different as far as air quality humidy ect... Its always good to know what your motor is doing in real time all the time... Stay away from those cheap A\F gauges that use the narrow band sensor.. They are very jumpy and inaccurate... Waste of money..
#12 | |
8.7 in the 1/8th
AEM makes a very good wideband/UEGO sensor/guage combo. They are pricy, but... How much is your motor worth?
#13 | |
Here check this out...
Threads Similar to: Anything else needed to support a Supercharger?
| Radiator support | Pharoh | V6 Mustangs | 3 | August 16th, 2007 10:17 PM |
| Changing core support? | 8A_Honda | 5.0 Mustangs | 6 | June 8th, 2007 07:51 AM |
| Whipple Supercharger - Installation Tips Needed | sechmura | 2005 - 2010 | 1 | June 6th, 2007 08:18 AM |
| MM Support Group | oldernewbie | The Clubhouse | 24 | January 29th, 2007 06:36 AM |
