LinkBack (2) | Thread Tools |
#1
306 Engine Combo?
I am building an engine combo and want to know what you guys think about it. like combonation potential, estimated hp/tq numbers
Here goes: 306ci using A4 block Scat 4340 Forged steel crank and rods TRW L2249F pistons (12.0.1 compression ratio) Lunati cam (242/252 duration @50) (600/620 Lift) (110 LSA) AFR 185 Heads Trickflow R Intake 75mm TB 76mm MAF 30lb Injectors 1 5/8 Longtubes theres more but these are the basics Thanx |
Im not good at the guessing game but maybe like 330-350 rwhp. Just one question, is that all that you are doing to it? Keeping it NA? If so, why the A4 block?
![]() 93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc. 88 GT "Big Blue" - Body work & primer! |
Should be no problem making 340hp or so at the wheels.
What kinda crazy head and piston combo is that to make 12:1 and have a cam with 600/620 lift?
I can't find those pistons online, so I don't know their specs, but do they have a dish in them the size of a grapefruit? |
#6 | |
#7 | ||
Sorry I made typo.
The Pistons are TRW L2249N, Not the NF ones. The L2249NF have a 4cc dome and have a 10.5.1 ratio with a 58cc head and the 77 & later 8.206 302ci deck height. The L2249N have a 7.8cc dome and have a 12.1.1 ratio with a 58.2cc head. They dont make the L2249N piston anymore. The cam is the Lunati 51018 hydro roller cam. Its got 560/576 lift but with my 1.72 rockers it would have 600/616 lift I also have an NX plate kit that I might throw on it. I want to see how it does N/A first. Also, one of my freind said that anything over 24lb injectors and a really big cam is going to need a custom tune or it wont run good. Do I need a tune ? |
i havent seen the pistons but they gotta be something else to have that big of cam and afr 185 heads all fit. and if u get that working i would def say upwards of 360 wheel. but i dont c how ur gonna get he pistons to not smack the valves with that cam and those heads. but all the same good luck
You're got a heavily modded car for the street, so a tune won't hurt. You won't need a tune necessarily just to run well. The MAF will take care of the injector sizes, so you don't have to worry about that. 24 is only a notch up from stock, so that's not too serious a change, but yay for computers because it's all taken care of with MAF calibration.
But if you still have more plans, hold off on the tune until you get everything done. Edit: I misread about your injectors, but even with 30lb it doesn't matter. Just make sure you have the right calibration for the MAF, get good fuel pressure and that's your fuel system worries taken care of. |
#11 | |
#12 | |
Why would the pistons smack the valves? I have off the shelf Probe pistons and a cam with over .700 lift and my valves don't come anywhere near my pistons. I've run .620 lift with stock pistons already. All aftermarket pistons have valve reliefs and most aftermarket pistons have larger and deeper valve reliefs than stock pistons. Valve timing has more to do with piston to valve clearance than anything.
I didn't put the heads on yet so thats a plus for PTV clearance.
Do you think the valves will hit. The pistons do have pretty deep valve relifs. |
#14 | |
Can he run pump gas with 12:1 comp?
I've always heard no more than 11:1 on 93 octane, and even with that you're gonna have some pinging going on more than likely. But a higher octane mixed with 93 would probably be the best bet.
'87 Mustang 5.0 T5 Coupe New motor I/P: stock shortblock Edelbrock heads Typhoon Intake 70mm TB 80mm MAF 24lbers 1.7 rr B303 cam. Shooting for 300rwhp? |
#17 | |
#18 | |
Thats what I thought.. But I could be wrong.. Been know to be..
#20 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/16395-306-engine-combo.html
| 1968 289 H2O - Page 6 - Mustang Forums at StangNet | This thread | Refback | April 24th, 2011 01:38 PM | |
| 1968 289 H2O - Page 6 - Mustang Forums at StangNet | Post #8 | Pingback | April 24th, 2011 01:18 PM | |
Threads Similar to: 306 Engine Combo?
| sub and amp combo | gkizzle3622 | Audio/Video | 4 | October 29th, 2007 07:47 PM |
| How does this combo run | fasta$$306 | 5.0 Mustangs | 2 | July 26th, 2007 01:56 AM |
| improve my new engine combo | phillipstheman2 | 94-95 | 6 | July 11th, 2007 10:09 AM |
| new combo!!! best cam??? | luizGT91 | 5.0 Mustangs | 5 | April 13th, 2007 10:46 PM |
| 12 Second Combo | Tim Stewart | 5.0 Mustangs | 3 | September 21st, 2006 05:34 PM |
