#1 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
speed density with stage 2 cam
I read something about having to re-program the computer if I want to do a top end kit from trickflow. But I just want to know exacly what I have to do to my car as far as the speed density. Im sure there is a better way than the mass air conversion($600). anyone have a top end kit with speed density?
After I get the kit installed I will upload a video on google. the only 5.0 I could find only had the stage2 cam with ed-L-brock heads.
#3 | |
The stock cam makes a lot of vacume apperently a aftermarket cam will not make the same and will not be able to idle or some shit.
You can convert to mass air for about $200 or so. Interactive Technologies makes the harness for $29 and you can get the computer and mass air from a junk yard for $150-$200.
there is a way to use sd with big cams. the thing is called megasquirt or something similar to that. a friend is running a sd setup on a 357 w with a big custom cam and afr185 heads. thats the only way i can c it working other wise its a maf conversion for u. and it aint that expensive to do the swap the ecu and everything from a junkyard wil run u 150-200 like darrel said. i will do some more research on the sd setup thing and post it when i get it.
Megasquirt has nothing to do with a stock EEC though. Many aftermarket EFI systems are speed density. Factory Ford EECs are the only systems that have issues with speed density.
Threads Similar to: speed density with stage 2 cam
| Cai for Speed Density | Drick | 5.0 Mustangs | 16 | September 19th, 2007 11:20 AM |
| speed density cam options | itsmyfiveoh | 5.0 Mustangs | 4 | May 13th, 2007 06:01 PM |
| Speed Density VS MAF | Tr1gger | 5.0 Mustangs | 7 | April 17th, 2007 11:24 PM |
| Speed Density or MAF? | 8A_Honda | 5.0 Mustangs | 15 | February 6th, 2007 09:04 PM |
| Speed Density | Darrellx14 | 5.0 Mustangs | 4 | December 2nd, 2006 09:50 PM |
