Discussing power loss at part throttle? in the 5.0 Mustangs Forum. hi fellows i posted the question limp mode under my brother in laws id any ...
Old April 6th, 2006, 01:21 PM   #1
hi fellows i posted the question limp mode under my brother in laws id any way here it is i purchased a 95 cobra when i got the car it was wrecked but running i believe the car has had the engine rebuilt (due to chevy orange block and arp head bolts) ialso think the cam is aftermarket the egr was not connected so i just pulled it off i also in search of a little knock on the top end pulled off the intake got dissgusted with how small the factory tb is and replaced it with a 75mm tb i have an intake on the way so that it flow better. now the check engine light is on i had the codes checked and it pulled nine of those little buggars. I would like to know if there is some way to trick the pcm into thinking there is nothing wrong cause i really dont want to put hot exhausted gasses into the intake any info any one might have on this would be greatly appreciated. Also was curiuos as to wether or not it could be other sensors triggering these ones and if not where do i start. thanks again. here are the codes 327 came up twice 113 122 158 181 189 332 542 koeo engine off test. koer codes running test 314 311 327
Threads Similar to: power loss at part throttle?
Could This Cause Loss Of Power VSR13 V6 Mustangs 24 December 14th, 2007 10:08 AM
Loss Of Power! Help Please! alamo11 V6 Mustangs 8 December 14th, 2007 08:34 AM
power loss? xedubx 99-04 16 June 20th, 2007 09:52 PM
Loss of low end power ByPopularDemand V6 Mustangs 24 May 10th, 2007 09:00 PM
Power Loss the hammr 5.0 Mustangs 8 August 17th, 2006 08:48 PM
