Cam swap worth it?
Old March 14th, 2007, 03:08 PM   #1
hitorx's Avatar
1981 Mercury Capri
hitorx is on a distinguished road
Send a message via MSN to hitorx
Cam swap worth it?
I got 306CI
Forged pistons 9.6:1
Stage 1 ported World Windsor JR heads(up to 560 lift) W/1.6 rocker
AirGap Intake
650 Double pumper Car
Longtube 1''5/8
Exhaust 2.5''
3.55 Gear
T5 transmission
(this cam in my engine)
Hydrolic Roller Camshaft by compcams 35-440-8 or 281HR
281In 281Ex Duration
220In 220Ex Duration@50
512 Lift
110 LSA
2000-5500
I want to use this one and need advice if worth it:
Hydrolic Roller Camshaft by compcams 35-430-8 or 280HR
280In 280Ex Duration
224In 224Ex Duration@50
560 Lift
110 LSA
2500-6000
Thank you
Old March 14th, 2007, 03:12 PM   #2
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
I don't think I would spend the time to change it. I know the lift is bigger with the second one, but the duration is almost the same. So much of the time is spent below the peak lift that with the same durations, I doubt it would make much difference.
Maybe if you were doing a lot of other work and already had the heads taken off, I would go for it, but I wouldn't set the time just to swap those two cams.
Threads Similar to: Cam swap worth it?
Motor Swap- 302 up to 390 FE. Possible?? how hard, worth it? stillnotfastenough4me 5.0 Mustangs 23 December 14th, 2011 08:11 PM
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
Is it worth it? chris1 99-04 33 August 25th, 2007 03:26 PM
is it worth it??? mustang95HO 94-95 5 November 30th, 2006 11:35 PM
