How much lift at lifter?
While I got the heads off I figured I would check the lift using a dial indicator on the lifters to see what size cam is in the motor.
I bought this motor used and it seems to have a small cam in it due to the idle and powerband. Its a 306 and the pistons have valve reliefs, an 86 roller block. The heads were e6's but it doesnt matter cause im changing those. So what kind of lift should I be looking for on an 86 roller motor. I read somewhere that .444 lift was stock cam but thats after the 1.6 rockers. So I was thinking around .275 lift at the lifter? Does that sound right? Thanks in advance for any help. |
95 opalfrost gt
You shouldnt be looking for anything accept what reading you get at .050
lift.
Divide total lift by rocker ratio and that will give you lobe lift.
.444/1.6 = .2775
Threads Similar to: How much lift at lifter?
| Max Lift | javier351lx | 5.0 Mustangs | 2 | July 11th, 2007 10:35 AM |
| Lifter tick identification | wanabebuff | 5.0 Mustangs | 15 | June 12th, 2007 07:02 PM |
| stuck lifter | whiteboycustom | 5.0 Mustangs | 4 | March 9th, 2007 06:04 PM |
| Lifter Tapping... help? | Stan27 | 99-04 | 11 | February 21st, 2007 12:17 AM |
| Flat Lifter | Euroeater95 | 94-95 | 6 | October 13th, 2006 01:57 PM |
