Valve train clacking sound. Need help.
I just got my 93 mustang gt. It has a mildly built 302. The bottom is stock, but the upper has some good mods (hydraulic roller setup, top to bottom). I have had it for about 3 days and have about 3 hours on the motor. Everything was running very well until last night. I had been taking it easy with the motor and I went ahead and rapped out the RPM's to about 5000 and smoked the tires for about 2-3 seconds. After I rapped it out, I noticed a clacking sound from within the valve train. I think that it is an issue with the lifters but I am not sure. I want to change the oil and see if it helps with the lifters if that is the problem. Does that sound like a good way to start?
Moderator
could be, I had the same problem with my 89 and b4 I could figure out what it was I decided to pull it and start working on my stroker. Oh, yeah welcome to the site.
![]() ![]() BUILD 2 IN PROGRESS |
Moderator
also, check this out and see if this discribes your problem.
http://www.moddedmustangs.com/forums...tml?highlight= if it does i hope that it helps
Thank you for the info. I do believe that I will change the oil first and see if that works. If not then I go to the next step.
Had you, or anyone, done any work on the valve train or heads recently?
Threads Similar to: Valve train clacking sound. Need help.
| Cam and valve train??? | flamed 98 gt | 96-98 | 8 | November 2nd, 2007 02:58 PM |
| Calling out 97 stanger on the BS train | ESG-642T | The Clubhouse | 227 | May 20th, 2007 02:09 PM |
| valve train chatter question | USMC SCOUT SNIPER | 5.0 Mustangs | 0 | January 11th, 2007 10:19 PM |
| Drive train? | BravoTeamLeader | 5.0 Mustangs | 1 | December 17th, 2006 06:39 PM |
| Valve Train Noise? | superbeef1000 | 99-04 | 3 | September 10th, 2006 08:42 PM |
