Need help with building a 347 !!!!
Old April 7th, 2006, 01:19 AM   #1
91stan's Avatar
91stan is on a distinguished road
I am new to this website and I need some help. .. I am building my first motor and 347 stroker for my mustang sound good from a 302 block and i have not bought anything so far because i dont know what block to buy and exc.. people say to buy a race block but where do I buy one at. Does anyone know a website i can go to for a step by step on how to do that or maybe someone on here can help me? There was some things I am having problems with, like do i need a block with a 1 piece rear seal or a 2 peice, an I was told to use a 351 cleveland crank but I didn't think that will fit because i thought that was for a big block. Any help?
Old April 7th, 2006, 07:33 AM   #2
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
If you want a race block then go with a DSS short block. I like them. There are many place that manufacture aftermarket racing blocks and there are also many places that make complete stroker kits with the crank in the kit. The search engine will be your best friend on this. Oh and also check the magazine rack. The monthly mustang magazines are ALWAYS reviewing an aftermarket block. As for the how to. There are many people on here that can help you with any questions you have as you go through the build and there is also a few books out there that can tell you anything you want to know just for the 302/5.0 motor. Hope this helps Stan!
Old April 7th, 2006, 07:54 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
How much horsepower do you plan on making? That will be the deciding factor for alot of your parts. 500hp and under 7000rpm and naturally aspirated you can use a stock 302 block with an Eagle cast crank, Eagle I beam rods and a set of hypereutectic pistons. If you plan on making more than 500 hp and/or a power adder you will need to invest in a Dart or World block and forged internals. If you want to cut some costs you could build a 351 Windsor and use a 70s block. They will handle 700+ horsepower all day. What ever you do make sure you go to a good machinist. Good machine work and assembly is what makes engines live long. Stay away from 351 Cleveland junk. And no a Cleveland is not a big block.
Old April 7th, 2006, 05:43 PM   #4
vfast will become famous soon enough
that DDS block is still a stock piece.....
Old April 7th, 2006, 05:50 PM   #5
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
get a used block because of the heating up and cooling down for years they are well seasoned and the steel is harder new blocks are not as strong and if you want power a seasoned block is the way to go
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old April 7th, 2006, 09:15 PM   #6
Aliate X is on a distinguished road
Send a message via AIM to Aliate X
DSS motors are crap IMO. I would go CHP (coasthigh.com) really good stuff, and you can get them with whatever block you want.
Everything + Nitrous
Old April 8th, 2006, 01:33 AM   #7
91stan's Avatar
If I go with a 70's 351 windsor block and stroke it, I will get more power and more then likely be cheaper then going with a 302 race block and build it. I am wanting to build a stroker motor for a 79 mustang lx no nos or supercharger. Just motor and get 550hp or more. But I dont want the best of the best if you know what I mean. $ is tight right now and I will be buying a little as I go. I guess I need to start by trying to find a 70's 351 and go from there. I have a motor here but not sure what it is, i have a friend look at it and said it is a old 352 motor from the 50's or 60's.. .. BTW the car will be setup to run 1/8 mile, the race tracks around me are 1/8 only......... Thankz for everyones input, been alot of help
Old April 8th, 2006, 08:23 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'll have a 425 for sale at the end of summer that makes 559 hp at the wheels and has gone 5.90s in the 1/8 mile in a 3100 pound car.
Old April 11th, 2006, 04:49 PM   #9
well if $$$$ is tight your not going to see 550hp's....you might be better buy'in the engine above which would have a much better block(351)
Old April 11th, 2006, 08:07 PM   #10
1gunner23 is on a distinguished road
wasn't the 352 a truck motor?
Old April 11th, 2006, 08:20 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
352s were in trucks as well as full size passenger cars. 352 is an FE series big block which is the same family as 390, 406, 427, 428, etc. Its pretty much a useless motor. Not much of an aftermarket for it.
Old April 12th, 2006, 12:11 PM   #12
IcantDo55 is on a distinguished road
Nice vision but if you want 550 rwhp you are going to have to spend some $$$ expect $7,000-$10,000 for a setup that could get you close to that hp # any leff and it will be a ticking time bomb. Be realistic build somthing nice you can afford, don't throw alot of $$ at it than skimp when you go broke.
Here a few estimates:
Blcok + machine work and assembly and ballancing:
$2,000
Rotating assembly +ballancer:
$2,000
Heads:
$1,500
Valvetrain:
$750
Intake + carb: (Lets guess carb because it would be cheeper)
$600
Trans:
$1,500
Cooling system:
$500
Ignition:
$500
Fuel system:
$1,000
Expect more and if you don't do all thwe work yourself it will be much more. Just be true to your self and build what you can afford to finish, you will enjoy iy more.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old April 12th, 2006, 08:44 PM   #13
$2,000
$2,000 about 1500.00 here
Heads:
$1,500 used around 700.00
Valvetrain: good shopper around 300
$750
$600 used intake 75.00 factory rebuild holley 175.00
Trans:
$1,500 at least 1500 for an automatic
Cooling system:
$500 3 core rad 125.00 ...electric can 75.00 high flow wp...75.00
Ignition:
$500 a good used (100) MSD 6al will do with a $40 coil..75.00 for low ohm wires
Fuel system:
$1,000 about 200 for this
kinda high..remember some used parts will work
Old April 12th, 2006, 09:07 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
$2,000
$2,000
Heads:
$1,500
Valvetrain:
$750
$600
Trans:
$1,500
Cooling system:
$500
Ignition:
$500
Fuel system:
$1,000
That estimate is a little on the low side but might be do able with used parts.
Old April 12th, 2006, 09:09 PM   #15
you think?.......do we always disagree
I have 6500 in my whole car and is about 525 @ the wheel
Old April 12th, 2006, 09:13 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'm curious to the break down of this. Are we talking N/A or with a power adder?
Old April 12th, 2006, 09:18 PM   #17
I have a vortech s-trim also a tremec 5 speed, drag shocks etc the whole 9 yards.....
Old April 12th, 2006, 11:44 PM   #18
To see 550 rwhp out of a 347 you going to have to SPIN that thing. And with Hi-RPM comes high $$$ parts to deal with it.
I vote stop all the maddness get a 347 on a stock block and spray it with 100 shot and be happy. Cheep and works.
-Mike
Link to My Site
Stroked and Blown!
Old April 13th, 2006, 07:31 AM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Well with a power adder it is very possible using used parts. If he can pick up a used s-trim he'd be set or a bottle for that matter. With my power adder I lay down just under 1000 hp at the wheels.
Old April 14th, 2006, 01:06 AM   #20
Whats your setup?
-Mike
Link to My Site
Stroked and Blown!
Threads Similar to: Need help with building a 347 !!!!
Building a 306??? JONJON 5.0 Mustangs 57 October 22nd, 2007 09:47 PM
building a 1985 gt FastBack71 5.0 Mustangs 21 March 8th, 2007 10:31 PM
building mustangs seat cover company New Members Introductions 4 March 4th, 2007 02:12 AM
Building the rear.... stangliter04 99-04 1 February 28th, 2007 01:07 PM
Building a motor DirtyMach1 The Clubhouse 22 November 16th, 2005 03:34 PM
