Transgo Shift Kit question
Anyone have experience installing a transgo shift kit? Is it dificult or time consuming to do? could I do it in my garage with just jack stands and a floor jack? Also, has anyone had any bad/good experiences with them?
-Mike
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
I have never done one, but my buddy is doing a valve body for me...he says they are easy to put in.
And yes i have experience with them, it will wake up that tranny of yours. There are two different ways you can go, i would personally go with the harder shifts. While you are working with the transmission, are you going to put in a higher stall or a trans cooler? Those are two mods you want to do sometime as well.
I was thinking very seriously about putting a trans cooler from ford racing on it as well. As far as a torque converter, I havn't considered it because I'm a college student on a budget. I know that the AOD is pretty week so I figured a Transgo kit on it with a transcooler from ford racing would wake it up a little and cause a lot less heat. I have had bad experience with ford transmissions, the AOD being one of them. I figured if I run it with this setup it would seriously extend the life of the transmission.
Just follow the directions and you should not have a problem.just make sure you use a inch pound torque wrench and proper torque sequence.
you really cant go to big with a trans cooler.heat is the #1 killer of transmission.one thing you should do is change the TV cable grommet on your TB if that breaks and they commonly do it will cause premature trans failure
Threads Similar to: Transgo Shift Kit question
| 4:10 and Transgo HD2 shift kit installed | jrfan4life | 99-04 | 1 | November 11th, 2007 01:57 PM |
| Transgo shift kit | Tony_90fox | 5.0 Mustangs | 6 | November 7th, 2007 05:50 PM |
| Gears and shift kit question | 302pusher | 5.0 Mustangs | 2 | July 24th, 2007 10:29 AM |
| Shift -vs- RPM question | thomaspatton | 5.0 Mustangs | 12 | May 25th, 2007 10:44 PM |
