Fuel Problems Burning Rich / Burning Lean
Old March 15th, 2007, 08:33 PM   #1
Steves LX is on a distinguished road
I have a 89 LX that seems to not be burning fuel right. If I sit an idle and then pull the plugs I have 1 or 2 plugs that are chocolate brown and then then the rest of them are either white or a light grayish color. If I drive the car and then pull them they are all grey or white. Somethings not right but I dont know what. I also noticed that the vacum hose that comes off the vacum tree on the firewall that goes on the upper intake on the back if you pull that off the intake the hose has oil that drips out of it. This is a 302 with 24# injectors, 75mm TB, C&L MAF, and a Edelbrock 5.0 performer manifold and intake. I have tried setting my fuel at 35 and 40 and still does the same thing. Any help would be appreciated.
Old March 16th, 2007, 03:05 PM   #2
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
check you plugs, plug wires...you might also have crossed plug wires.
Modifications and pics in my Garage...
Reps Appreciated!
Old March 16th, 2007, 03:06 PM   #3
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
hope this helps.
Reps Appreciated!
Old March 20th, 2007, 11:40 PM   #4
MySallyMI is on a distinguished road
Re: Fuel Problems Burning Rich / Burning Lean
Where your two browned plugs wet? if so get new plugs. Try cleaning your MAF sensor, carefully (i never have myself but had a similar problem and was told to do this with brake cleaner). When i thought i had a fuel pressure issue i was told 39lbs is the optimum to set the regulator at.
Old March 21st, 2007, 05:11 PM   #5
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Do not use brake parts cleaner. There are specific sprays to use on electronics, look for those.
Old March 21st, 2007, 10:46 PM   #6
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
YES there are sprays specific to electronics and electronic connectors. one quick blast and the MAF is clean....no need of taking it off either...just take the air filter off....
Reps Appreciated!
Threads Similar to: Fuel Problems Burning Rich / Burning Lean
burning oil??????? 5LBennett 5.0 Mustangs 20 July 4th, 2007 12:34 PM
burning oil dragpipe General Tech 0 February 25th, 2007 04:40 PM
Burning Oil thewayshemoves 99-04 4 December 27th, 2006 12:25 PM
Need Help Burning Very RICH!!!! giddyup91 5.0 Mustangs 7 December 1st, 2006 03:44 PM
Burning Oil terribleonexx88 5.0 Mustangs 11 November 13th, 2006 11:45 PM
