Front-End
Old March 15th, 2007, 11:36 PM   #1
Stangzilla's Avatar
Stangzilla is on a distinguished road
Front-End
This if for anyone running a front K-Member and coil-over springs.. Does if at all you front end make any noise Creaks pops ect sometimes.. I have been told that is normal but to what extent if so?
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 17th, 2007, 07:08 PM   #2
Stangzilla's Avatar
Cmon I cant be the only one running a K-Member and Coil-Overs.. Anyone??
Old March 17th, 2007, 10:00 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
Hey bro I talked to my buddy that has that set up (not sure what brand) but he called the company and they had said that it is normal (company technician). But regardless he says that it still annoys the shit out of him. Ill let you know what brand he has when I talk to him later on tonight.
BUILD 2 IN PROGRESS
Old March 17th, 2007, 11:19 PM   #4
Stangzilla's Avatar
Thanks man..
Old March 17th, 2007, 11:34 PM   #5
dmarstroker's Avatar
dmarstroker is on a distinguished road
What brand k-member and coilovers you runnin?
Old March 17th, 2007, 11:39 PM   #6
Stangzilla's Avatar
I have a AJE K-Member & control arms with D&D coil-overs with Strange Engineering adjustable struts...
Old March 18th, 2007, 07:28 PM   #7
Stangzilla's Avatar
Anyone else please... Darrell? Anyone?...
Old March 18th, 2007, 08:19 PM   #8
How much backspace do you have on the front wheels? I've always wanted to fit 17's with coilovers up front
Old March 18th, 2007, 08:22 PM   #9
Stangzilla's Avatar
I have the 17x8 Cobra wheels. They came with the car I never measured them but my guess is prob 5.5 to 6? The springs are pretty close but do not rub....
Old March 18th, 2007, 08:24 PM   #10
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
I dont run a k-member for that reason. I was going to, until I started reading up on them and found out that most of the set ups will squeek and make noise.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old March 18th, 2007, 08:32 PM   #11
Stangzilla's Avatar
Well that's not my concern I just want to make sure its normal and I did it for the weight loss because I want to get the front wheels off the ground at the track.. And I run long tube headers, and there is nothin like workin on your car with a K-Member.. More room than you know what to do with...
Old March 18th, 2007, 08:33 PM   #12
IcantDo55 is on a distinguished road
The front strut towers on fox bodies were never designed to hold the entire wight of the front of the car and will eventually crack. Your hearing things cry for help.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old March 18th, 2007, 08:52 PM   #13
Stangzilla's Avatar
No its not a cry for help I just put them on a couple a months ago. How is it any different than the stock setup? The spring is still in the center and pushes up like the coil overs do.. Also the coil-over springs I have do not exert as much as the stockers do.. I dont think thats the case.. It has more to do with the design of the K-Member... I dont buy what you said...
Old March 18th, 2007, 08:58 PM   #14
On the stock setup the weight of the car is put on the spring that is set between the lower control arm and the FRAIL RAIL! The only thing pushing on the strut tower is the damper (strut). Big difference.
-Mike
Link to My Site
Stroked and Blown!
Old March 18th, 2007, 09:08 PM   #15
Stangzilla's Avatar
But the weight difference because of the aftermarket K-member makes mostly up for it.. Any way its not a cry for help.. My towers are solid as can be... There is still alot of upward pressure on the whole system anyway stock or not.. But whatever.. Thats not a concern of mine anyway.. But thanks for your input 55...
Old March 18th, 2007, 09:33 PM   #16
No problem.
-Mike
Link to My Site
Stroked and Blown!
Old March 19th, 2007, 03:39 AM   #17
88BlueGT is on a distinguished road
Send a message via AIM to 88BlueGT
I hope that they dont make noise! Im getting ready to install:
D&D K Member
D&D A Arms
D&D Coil Over Kit w/ 10" 250lb springs
Strange 10 Way Adj. Struts
Maximum Motorsports C/C Plates
Depending on spring size you can fit 18's on your car with the right spring. I know w/ D&D 17's should fit on a 12" spring... but the smaller the spring your launch will suffer. I think Im going to get a set for the track also, maybe like a 14" 150lb spring... dunno yet. GL and let me know how it goes!
93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc.
88 GT "Big Blue" - Body work & primer!
Old March 19th, 2007, 11:18 AM   #18
Stangzilla's Avatar
D&D K Member
D&D A Arms
Well they do make noise....
Old March 19th, 2007, 12:16 PM   #19
88LSC is on a distinguished road
that upward pressure is for the k-member not the flimsy strut towers on the mustang.that's one of reasons why there's a "modified" MacPherson strut.use a k-member with spring pockets on a street mustang or at least use a strut tower brace if you must have coil over's.
if you can't get the front wheels off the ground with the stock k-member you got other problems.
Old March 19th, 2007, 05:42 PM   #20
Stangzilla's Avatar
Dude you have no idea what my car has so just keep your thoughts to yourself because I will put my car up against you shitbox anyday!!!
Threads Similar to: Front-End
gt 500 front end mystangsak 2005 - 2010 3 July 6th, 2007 04:55 PM
Front Bra Kennhyy3 V6 Mustangs 4 May 8th, 2007 10:33 PM
17 by 8 up front on a fox dmarstroker 5.0 Mustangs 6 March 23rd, 2007 09:37 PM
Cobra front? ROUSH Front? or Mach1 Chin? Chris02 99-04 11 November 19th, 2006 01:10 AM
Front End ttop5.0 All Other Vehicles 0 June 28th, 2006 10:03 PM
