What Fuel Octane To Use?
What octane to use for my stock 88' 5.0?
you could get away with running 87 octane if you really wanted.
it looks like the compression ratio in your car is the same as my 93' probe GT, which is around 9:1, and I ran 87 in there. |
11.47@120.58
87 is best unless you get pinging while running it, then maybe 89. It's best to go as low as possible, too much octane can hurt power and cause other issues long term.
I just got some 87 and drove around for a bit....no pinging at all.
I guess I'll stick with the 87.
El Conquistador
i use the 93, its what i use in my truck to, now for my honda 450r quad i run sunoco gt plus 104, thats the best dang gas i have found to run in it, the cleanest running by far
more octane means you can run more timing...more timing=more HP. go with as much octane and timing as you can afford. my2cents
11.47@120.58
Precisely, though without more timing you're wasting money and probably power. My car lost 8hp on race gas until the timing was added. 4* timing made another 40hp.
you want to run as close to detonation with out detonating.if you are not
pinging with 87 your fine.
#9 | |
is 93 octane at 14 degrees too much octane?
#11 | |
In order to get the most power from your gas, you need to match your timing to the potential of the octane used in your engine. Racing fuel will give you a little more power without modification, but to get the full benefit of racing fuel, you new to advance the timing. Advancing the timing gets the engine to burn the fuel in a manner that harnesses the most power possible (as Darrell said, right before detonation). Of course, this applies to all levels of gas, 87 - 93 (ha!! never realized that before!!) and 103+ octane. The topic creator asked about a stock 88, which can get by with 87. But for anyone else out there who has a non stock 'stang, see how far you can go with octane and timing before detonation shows up.
#12 | |
Wait, what the fuck? Tony's just wasting our time. . ."too much octane"? From pump gas?
well i just wanted to double check. Above said too much could end up hurting engine....But i was told that i had it right a long time ago, just wanted to check while we were on topic
I bet i could go up to 15-16 degrees. No pinging, it runs pretty good. I might try it tomorrow if i dont run into too much work already!
Yeah, I'd like some justification for that. At least some clarification between "running too much octane" and "not setting your timing to the amount of octane you're running."
I could come up with an argument about how running 103 octance at stock timing would hurt our engines, but maybe he had something else in mind. |
FWIW my timing is set to 18* and i usually use 92, sometimes 93 octane. but every engine is different. only way to get it right is to test and tune
'95 GT
Was probably faster before I got it.
Hey for a stock 95' Mustang GT v8 5.0 Liter what fuel octane is recomended?
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
The cheapest thing that doesn't make you ping.
'95 GT
So just regular unleaded?
Sure, if you get away with it. If you're all stock then you shouldn't have a problem.
'95 GT
ok sweet and thx
Threads Similar to: What Fuel Octane To Use?
| 93 octane? | petrol_head | 5.0 Mustangs | 9 | July 16th, 2007 08:12 PM |
| 93 octane fuel | jersey98gt | 96-98 | 12 | May 9th, 2007 12:38 PM |
| Gas octane | ByPopularDemand | V6 Mustangs | 11 | May 6th, 2007 08:30 PM |
| Fuel Octane Question | zreg | Classic Mustangs | 5 | December 1st, 2006 08:36 PM |
| What octane should I run | f8yd2blk | The Clubhouse | 9 | May 11th, 2006 08:36 AM |
