Trans swap?
How hard whould it be to swap from a t5 to a automatic trans and what would I need to do?
I did that swap already so you will need the following,
clutch brake pedal assy clutch cable T5 trans and bellhousing pilot bearing flywheel dowels flywheel to crank bolts pressure plate bolts shifter OPTIONAL steel bearing retainer three hook quadrant firewall adj.
its fairly easy. you are also going to have to drill another for the speedo cable because the hole that its in is where the clutch cable needs to go through.chances are you are going to get a pedal assy. without stock quadrant so you will need an aftermarket quadrant and a aftermarket
clutch cable. you can check UPR products for that.I also recomend the MGW shifter there the best shifter out there.the rest is pretty much straightforward. I forgot to mention a clutch fork . there are a few good ideas you could follow ,one is to install a steel bearing retainer which makes for a much smoother clutch action .the aluminum ones suck. for strength you could get a rear main shaft support.
Smack me if I am wrong, but I believe he wants to go to an aod.
#5 | |
oops you will need the following:
Aod trans cooler lines TV cable(not needed for manual valvebody) remove pilot bearing 164t flexplate torque converter shifter&cable dipstick tube&dipstick bellhousing bolts flexplate bolts A/T pcm brake pedal assy. TV cable grommet(on TB)not necessary with manual valvebody large trans cooler its a pretty easy conversion.
Threads Similar to: Trans swap?
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
| C4 Trans Swap. | CantDrv55 | 99-04 | 1 | February 28th, 2007 02:54 PM |
| m5r2 trans swap | sylchoneycutt | 5.0 Mustangs | 0 | January 22nd, 2007 10:55 AM |
