bought a 5.0 with bulit motor, need advice.........
Old April 9th, 2006, 06:39 AM   #1
gixxer1 is on a distinguished road
the car is a 90 5.0 with edelbrock performer heads,compcams 512 lift ,solid lifters,30lbs injectors,80 mm maf meter,cold air intake, mac headers and adjustable fuel regulator............my question is i want to remove the solid lifters and go with roller. what cam to use? f303 or e303........and will it run to rich with 30 lb injectors? should i install 24's...can i leave 30's in?
the car is set up for drag racing and i want it more streetable and reliable....thanks guys
Old April 9th, 2006, 06:50 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why do you want to remove the solid cam? A solid cam is plenty streetable, especially a low lift cam like yours. They ran solid cams from the factory for years. So you might have to set valve lash once a year, big deal. A solid cam is superior to any hydraulic cam whether it is a flat tappet or roller. The 30lb injectors will work fine. You could put 24lb injectors in if you want but the 30 lbers won't hurt anything and will give you room to grow. Besides you would have to have your mass air recalibrated if you changed injectors.
Old April 9th, 2006, 07:21 AM   #3
i was told the solid cam would eventually hurt my valve springs...by a mechanic who drag races. should i just keep this set up? the engine also has 1.6 roller rockers to.........also what do you think i'm running for horsepower? ball park.....engine has stock rebulit lower end.........
also could i just install hydralic lifters? maybe roller? excuse me but i'm new to the solid cam deal......thank you
Old April 9th, 2006, 11:25 AM   #4
mdvaldosta's Avatar
11.47@120.58
The only thing that would hurt the springs is excessive lift... whether hydrolic or solid it doesn't matter. The only disadvantage with solid's having to adjust the valves to compensate for wear, as pointed out already. Usually alittle noiser too, especially when it gets close to adjustment time.
Old April 9th, 2006, 04:55 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Big solid cams (.700+ lift) require stiff valve springs which do not have a long life. Your cam is only .500 lift so the valve springs aren't going to wear out prematurely unless they are not the right springs for the cam to begin with. No you can not just install hydraulic lifters. You would have to get a different cam. The ramp profile is totally different. As far as horsepower goes, its hard to tell without knowing more specifics but I'd say you are in the 300 hp range at the wheels.
Old April 11th, 2006, 03:31 PM   #6
vfast will become famous soon enough
you will never get the long time wear of a hyd cam.....I didn't know compcam made a solid lift cam at 512 lift
Threads Similar to: bought a 5.0 with bulit motor, need advice.........
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
Just bought myself a '98 GT Dxpsman 96-98 24 April 16th, 2007 08:28 PM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
Twin turbo 03 cobra bulit by dagostino's black04GT Multimedia 14 July 24th, 2006 01:42 AM
