new roller rockers
i got a set of PRW 1.6 roller rockers for my mustang...ive got gt40 p heads...the rockers came with new base plates but i dont know if i need to use them or not...HELP
Yes
</shot in the dark> Why not use the parts that came with your new equipment? |
What do you mean by base plates? Are you talkin about pushrod guides?
If you use the pushrod guides you have to make sure you have hardened pushrods..
I think he's talking about plates (shims?) the rockers sit on.
95 opalfrost gt
Did you get pedistal mount rocker or did you convert to stud mount?
yeah, i think they are just shims...the heads are fully rebuilt and already have guides installed with the plastic or teflon on the ends, i did not know if i should use the shims....ive bought alot of parts that come with extras to meet different makes/models/setups....IE different heads may require different shims or bases but still use the same rockers...thanks
95 opalfrost gt
If your refering to the shims then you have pedistal mount and need the shims to set them set up.
pics FTW!!
they are stock gt40 p heads...with threaded studs sticking out of the heads for the rockers to slide over and nuts to tighten them down with
Stock GT40Ps had stud mount rockers? I thought they were pedestal mount?
i was told they were stock off of an explorer
95 opalfrost gt
someone must have converted them already. throw the shims away you wont need them.
pic..the shim is on the left
take a look at the pics and tell me what you think
95 opalfrost gt
That is a guide plate not a shim. you need hardend pushrods
#16 | |
thanks guys...appreciate the help
stuck again.....HOW DO I INSTALL THEM no matter how i install them, with the stock hardware or with the new guides they lock up and do not move...ill post some pics in a minute
pics with stock hardware removed
#20 | |
Threads Similar to: new roller rockers
| Does anybody make 5/16 roller rockers? | jtsik330 | 5.0 Mustangs | 5 | September 25th, 2007 02:06 PM |
| roller rockers? | superman5.0 | 5.0 Mustangs | 7 | July 26th, 2007 11:51 PM |
| Roller rockers? | aj28 | V6 Mustangs | 7 | July 15th, 2007 08:17 PM |
| Lifters and roller rockers? | MySallyMI | 99-04 | 6 | April 16th, 2007 06:30 AM |
