What should i set my fuel pressure at?
Old June 2nd, 2010, 12:23 PM   #1
95project is on a distinguished road
What should my FP be set at for:
Stock bottom end 5.0
AFR 185 heads
TR Track heat intake
75mm TB w/ 30lb injectors
76 MM MAF for 30lb'ers
MSD 6al, Dizzy, and coil
LT Headers, full exhaust
Custom CAM
SCT Tune
Will i miss the tune up by installing and setting my fuel pressure regulator? Thanks
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old June 2nd, 2010, 12:28 PM   #2
1992 Lx
11.39@119.24
why would you install one if youre tuned?
Old June 2nd, 2010, 01:00 PM   #3
for some extra tuneability...this MF'n car is sensitive...they had some troubles tuning it right and couldnt get the fp to regulate correctly all the way thru the power band...picked up a kirban for cheap...i had hoped it would help dial it in more.. am i wrong in assuming this will help?
Old June 2nd, 2010, 01:12 PM   #4
1992 Lx
11.39@119.24
My 3 tuned stangs have all been on the stock fpr so it always gets my vote
Old June 2nd, 2010, 01:30 PM   #5
any suggestion on what it should be set at?
Old June 2nd, 2010, 01:40 PM   #6
1992 Lx
11.39@119.24
39 with the vacuum off
Old June 2nd, 2010, 02:02 PM   #7
Trick Tuners's Avatar
KB'd GT
The fuel system is return style. There is no tuning involved with that. As long as the vac/boost line is attached to the regulator, the fuel pressure will be fine if there is enough pump capacity. If the pump is at max flow, adding an adjustable FPR will not solve the problem.
Old June 2nd, 2010, 02:35 PM   #8
Uber88GT's Avatar
1988 Mustang GT
Uber88GT is on a distinguished road
Sounds more like a fuel pump issue than a FRP. Like mentioned above, 39psi but if the pump can't provide that, your hooped.
Old June 2nd, 2010, 02:49 PM   #9
the fuel pump is the only thing not new in the fuel system...i will try your suggestion and see what i get...thanks guys.
Threads Similar to: What should i set my fuel pressure at?
Anyone got a spare set of pressure plate bolts? Matt300ZXT 5.0 Mustangs 0 August 29th, 2008 04:19 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
