Help: TB and EGR removal
Old March 18th, 2007, 07:29 PM   #1
nolife's Avatar
91GT, 88GT, 02GT
Do the TB and EGR plate mounting holes typically have threads or does the mounting bolts just slide through? I removed the four bolts to remove my TB and EGR plate and they refuse to seperate themselves from each other and the the upper intake manifold. I sprayed some WD40 in and around the studs and tried some agressive aggitation with a rubber mallet and a screwdriver but they are not moving at all. With the nuts removed, they should slide right off right? I even tried getting a screw driver tip in there and prying them apart but all that is doing is gouging up the TB and breaking screwdriver tips. The first picture is a side view showing the nuts removed from the studs, the second is a picture from underneath with intake manifold on the left, TB on the right (the assembly of the three parts stuck together as one is off the car and on my work bench).
Both the EGR plate and the TB are 70mm BBK if that matters.
Old March 18th, 2007, 07:31 PM   #2
IcantDo55 is on a distinguished road
Yep, they come apart. PITA after 20 years. You need a BFH.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old March 18th, 2007, 07:36 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
yea man.. just tap it a few times with something heavy and rotate your tapping. you need to break that 20 years of crap between the pieces is all
Old March 18th, 2007, 07:47 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
I wanted someone else to verify it was really just stuck before I take my mechanical aggitation to the next level.
Thanks for the help.
Old March 18th, 2007, 10:24 PM   #5
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Well, if it's aftermarket, it's not 20 years old, but the point remains the same. There is a gasket that goes between the TB and EGR, so someone may have put it on there with some kind of sealant. Of course you don't want to damage anything or screw up the mating surfaces; the EGR spacer has coolant going through so you don't want to introduce a leak.
Just be gentle. At first. . .
Old August 24th, 2011, 07:23 PM   #6
93 Mustang LX 5.0 5spd
N/A
easy-stangkin is on a distinguished road
Mine took some coaxing as well when I replaced it. Just used a rubber mallet and tapped all the corners and worked it off very slowly. Let me just say my 70mm Mac TB (note some port matching required on a stock intake) has been working very well.
Old August 24th, 2011, 09:15 PM   #7
50Droptop's Avatar
87 Mustang Lx
13.76@100
50Droptop is on a distinguished road
I used a BFH last time I took mine off
and broke my thumb at the same time.
Be careful lol
Shawn
87 Coupe
The Notch
Old August 24th, 2011, 11:02 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
Wow, this is an old thread, yes, I fixed it about 4 years ago. It took considerable force and a crowbar.
Once I got it apart, I threw away the studs and nuts and used stainless bolts instead. Now when I remove the bolts, there is nothing left for the EGR or TB to stick to and a light tap should separate them but I havent had to take them apart yet to verify. For my specific TB, EGR and upper, I think it required 3.5in long bolts.
Threads Similar to: Help: TB and EGR removal
removal of emblem trueballerisme 2005 - 2010 18 October 23rd, 2007 03:56 PM
pulley removal Plays With Squirrels 96-98 2 June 20th, 2007 11:21 AM
Decal Removal! sbland26 Visual 7 May 30th, 2007 12:51 AM
O2 Sensor Removal Dawgs2099 99-04 5 May 24th, 2007 06:56 PM
intake removal dumps 2005 - 2010 1 May 17th, 2007 11:53 PM
