LinkBack (1) | Thread Tools |
#1
1992 MUSTANG GT
N/A
Help 92 Gt Dying While Driving
OK all you guys and girls that have been messing with these cars for years just like i have , someone has had to have the same thing happen.
its a 92 gt runs great until going down the road just dies with no warning or anything some time it does it in about 3 miles from the house then other times it will do after about 30 miles it has no rhyme or reason just shuts off. sometimes it will start right back other times i will have to wait 10-20 min. i have replaced fuel pump, fp relay, eec relay, distributor, ign. module, coil, ign. switch, it seems like a ign problem but out of all the most common parts that go bad non of them have fixed the problem, but it does it so sparatic i cant do anything to make it screw up it just does. i ran the car all day sat. never messed up drove it home from my parents and never screwed up and that was about 50 miles of driving. monday it died on the way to work. if i had hair i would pull it out this car is pissing me off. ![]() please help |
check all your grounds, specifically your starter.
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
do you have a cam in it cuz that can be why mine use to do that cuz the cam was to big
I hope you are kidding...
1992 MUSTANG GT
N/A
I have an f303 but been in the car for about 5 years now so i dont think thats the issue
1991 GT
Never ran it
my 91 did that right after I bought it and it was the dwell module on the side of the distributor. I replaced it 3 times before I got a good one that didnt do it. Be sure you use the grease that comes with it....stops the heat/ voltage from screwing it up. Used an after market one from Performance Distributors and havn't had a problem since.
GTNBY2 |
#7 | |
1991 Mustang LX 5.0
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1992 MUSTANG GT
N/A
Thanks guys i will try another module after work and see if its the problem and if so i will get a goooooood one from perf. dist. company. i have checked into them before but never followed through
SVTfocus, F250
i got an accel one. but its recommended to get a brand new motorcraft one from ford
#10 | |
Other possiblilities are grounds and the computer.
Negative. A cam will not cause this issue. Your problem was not the cam, it was something else.
1992 MUSTANG GT
N/A
Well I Will Find Out This Weekend Or Tonight
1992 MUSTANG GT
N/A
ok well i tried new ign. module x2 ign. switch x2 checked all grounds and any other wire i could check and checked for spark when it did it and got spark not a good blue spark but a spark bypassed inertia switch checked coil ohms and voltage to make sure switch is working. i have come to the conclusion that the new reman dist. may be faulty and will get another in the morning and see if i can get it to happen again. if not that will check wires to module, ign switch and possibly replace computer car still driving me insane!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
SVTfocus, F250
remand distributors have caused hell with many people including myself. swallow the price and get a new motorcraft one
1992 MUSTANG GT
N/A
OK here are the codes with car running 94 44 33
now here are the codes with key on eng off 11 11 18 22 29 33 63 66 87 96 i was running codes every time eng running so today after the car did it again i ran the codes with key on eng off i have replaced ign mod, coil, pick up coil, map, ign switch, f.p., f.p. relay, eec relay,spout and connector, and tps all the codes point to the computer or harness correct , and i dont know if this has anything to do with it i drove it almost 50 miles when it was cool out after a good t-storm now at about 5 pm i drove it it cut out 3 times within 5 miles seems to do it more when its very hot and humid its about 95-100 degrees with heat index and humidity please any info would be greatly appriciated im tired of driving a chevy while its down. |
#16 | |
Here are some things to check. With the key on check the red reference voltage wire on the TPS, Baro and EGR valve position sensors. The voltage should be 5 volts. Check the wire at pin 1 for 12 volts. Verify with an volt/ohm meter that the wires at pins 40 and 60 are grounded. Pins 40 and 60 are grounded directly to the negative battery cable. There is another small ground coming off the negative side that has a strange connector about 10 inches or so down the wire. This is the EEC relay ground. Check that too. There is also a ground on the firewall that comes out of the wiring harness on the engine. This is the HEGO ground but check it anyway. Check pin 46 with the key in the run position. If my memory serves me correct there should be about 3 volts here. If all of this checks out then I believe you have a bad computer.
1992 MUSTANG GT
N/A
Well the computer is bad i did all the checks and every thing was fine so i pulled the computer opened the case and the capacitor was fried on pin 37 which supplies the power to everything now i cant find anyone that can get a e9zf aa (a9l) computer new, reman nothing around here.
So now i have found the problem i cant fix the problem ![]() Thanks for all of your help with this. |
1992 Lx
11.39@119.24
throw in an a9p if you can find one, they seem easier to come by and yes your car will start and run fine
#20 | |
A9L and A9P computers are easy to come by.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/169354-help-92-gt-dying-while-driving.html
| 92 Ford Mustang Gt Troubleshooting - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | June 26th, 2010 10:30 PM | |
Threads Similar to: Help 92 Gt Dying While Driving
| Wow my friend is dying ... no literally , hes dying | Youngin | The Clubhouse | 54 | July 21st, 2010 06:53 PM |
| Dying | mustangmad | 5.0 Mustangs | 0 | May 16th, 2010 07:59 PM |
| why is the battery dying? | YeloPony | 99-04 | 19 | March 30th, 2010 10:56 AM |
| Need some help, my Mach is dying | ZsMach1 | 4V / SVT | 23 | October 7th, 2008 10:39 PM |
| Help!!! Car keeps dying | NMR-2vGT | 96-98 | 1 | July 7th, 2007 12:40 AM |
