need some feedback...
Old March 19th, 2007, 07:49 PM   #1
1fastsedan is on a distinguished road
i am putting a 91 5.0 in my boat cause i blew up the 351w. i found this to be the cheaper route since i can make good power and engines are easier to find. here what i plan to do. cobra/gt40 upper and lower intake, 70mm TB and 76mm mass air, cam, rockers and fuel regulator.
my dilemma is what cam to use. i need to make up the torque im losing from the 351w. so which cam will provide good low end torque, which rockers (1.6/1.7) should i use. can i bolt the TB right up to the intake or do i need to use the egr spacer. the engine i have has 90k miles on it and it has newer heads, but i dont know the specs on the heads. they look brand new and the seller of the engine said this was his favorite engine out of the 5 he had because it ran very well. thanks for the help.
Old March 19th, 2007, 09:26 PM   #2
Racinjason81 is on a distinguished road
an e or b are cams that emphasize low to mid power there are many more
out there you will need an egr spacer ($50) so you can eliminate your egr and attach your throttle cable.your combo that you planned sounds ok
but you probably should get 24lb injectors if you still have 19s
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old March 19th, 2007, 09:31 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Re: need some feedback...
Was the orig motor carbed or injected?
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 20th, 2007, 05:58 PM   #4
injected, which rockers should i use? i also heard that the e and b cams are outdated any other solutions?
Old March 20th, 2007, 06:09 PM   #5
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
E and B cams still give you power.
Someone will bop in and say Trickflow Stage 1 or 2, but you can also try Comp Cams stuff.
Old March 20th, 2007, 08:44 PM   #6
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Without question the e&b are dinasours. With the stock heads any cam worth anything is gonna be a mismatch. Grab some gt40p heads or at bare minimum get the stockers ported. Then i would suggest talking with Comp and getting a cam an rocker set up from them. This is assuming your not looking to dump a ton of ching on this. BTW what type of boat is it?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old March 20th, 2007, 09:14 PM   #7
i just talked to my mechanic friend today and he is going to get some gt40p heads for 250 bucks. so i will put those on and he said he came across a bcam for real cheap brand new. my boat is a 1982 american skier.
Old March 20th, 2007, 09:36 PM   #8
where can i find a cheap egr block off?
Old March 20th, 2007, 09:46 PM   #9
95opal's Avatar
95 opalfrost gt
Use a 351 fuel pump block off plate summitt or local parts store $5.
5.0 magazines
Old March 21st, 2007, 11:18 AM   #10
Yeah, but son of a bitch, if I haven't been in a car running an E cam that can't keep traction to til he stops chirping in third (with a stock rear end, before you ask). Who gives a shit if it's old, it still works.
Old March 21st, 2007, 02:01 PM   #11
i have to run the o2 sensors right. that means i will have to drill and mount into my current exhaust set up. the manifolds i run have water that run through them to keep them cool, will the water effect the o2 sensors?
Old March 21st, 2007, 03:36 PM   #12
95opal's Avatar
95 opalfrost gt
Cause there are so many better choices these days. Those cams were designed when the only heads available were stockers or GT40 irons. So why wouldnt you take advantage in the technoligy and advancements that have been made over the last 2 decades.
5.0 magazines
Old March 21st, 2007, 03:38 PM   #13
95opal's Avatar
95 opalfrost gt
I take it the 351 was carbed? Why not stay that way?
5.0 magazines
Old March 21st, 2007, 06:27 PM   #14
the old 351 was carbed. i am limited on time to get this thing back in the water by spring. rebuilding a 351 isnt cheap and i have always been a big fan of fuel injection. so i found that going the 5.0 route was a little less expensive and i can make more power than the old engine. i bought a 91 5.0 with ecu harness for $1000 with 90k miles on it. i spend another $600 to beef it up and im in the hole for 1600 and on the water in 2 months.
Old March 21st, 2007, 06:31 PM   #15
95opal's Avatar
95 opalfrost gt
I dont know to much about boats to answer the 02 ? but Im sure if you hit a few boat forums they can help ya. I would love to hear that 5.0 w/ some transum exhaust.
5.0 magazines
Old March 21st, 2007, 09:27 PM   #16
So if you're sticking with stock Ford heads, does it matter?
Threads Similar to: need some feedback...
Some feedback please kmjsmith 2005 - 2010 5 May 31st, 2007 07:17 AM
Ebay feedback HMUSN The Clubhouse 15 May 4th, 2007 02:26 AM
feedback on rims 07stanggt Modular Mustangs 4 May 2nd, 2007 07:39 PM
Feedback Please ScreaminYellow05 V6 Mustangs 42 December 23rd, 2006 09:39 AM
My v6, need some feedback, PIX! kerry V6 Mustangs 25 August 31st, 2006 12:44 AM
