Discussing Losing HP in the 5.0 Mustangs Forum. My 87 5.0 is losing hp at 4000 rpms and higher when i stomp ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Losing HP
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
Sounds like a different problem. Even if the alternator wasn't working very well, you would still run off the battery. Besides, even if the alternator was dying, it either wouldn't work the whole time or if it had reduced output, it would still make more power at higher rpms.
When i drive the car when its cold it doesn't do it. When it warms up it starts to lose the hp. Do you think it could be my cats then.
#4 | |
Cats? What are those?!! LOL
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
IT'S TURBO TIME
1990 Mustang LX Turbo
sounds like a vaccumm leak???
Put up, Shut up, Line Up And Get Beat Up!!! |
I don't even know where to begin.
How long has it done that? Did you change anything? What all has been done to it? |
#7 | ||
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
buy a haynes and go throgh the trouble shooting. good tune up (plugs/cap/roter/fuel filter) a fuel pressure reg. carb build up? you got that oil sludge castrol gtx is talking about? seafoam engine cleaner and change oil+filter. I dont know if o2 sen matters but if you did all the above with no gain and your still on the stock ones...cant hurt. if you really want to have fun get some exhaust cut outs put ahead of the cats. warm it up and try it. loud is fun.
FREE LUNCH, FINAL WISDOM, TOTAL COVERAGE... WHY NOT?
#9 | |||
When i was building my car I have longtubes on it and took it for a ride before I put the exhaust on and honestly I did not like how it sounded at all.. I have a 347 with 10.5:1 compression.. Sounded way to loud and raspy.. hated it...
aod or manual? 3.73 for manual 4.10 for the aod. also a step up to after market heads. not sure on the spec of your cam either. aod stall converter?
i really think the 3:73 for this and 4:10 for this is retarded. I know people with manuals running 4:56s, and others who run 4:10s no problem in there manual, and the gas isnt bad unless you get on it every stop light.....It is really what you want to do with your car and base it around your setup.
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
Yeah you can run 4.56 gears with a manual if you want to spin 3500+ rpm at 70 mph.. To many rpm's for me..
#13 | |
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
See I run 275\40\17's and with a Tremec trans and 3.73 gears I turn 2900 at 70mph in 5th.. If I ran that gear with my tire I would turn prob 34-3500rpm. Like I said to much for me.. Fanatic are you runnin a 15 inch rim or a 16?
See, it just depends on your setup and how you want the car to run. Track time and high way time will have a deciding factor, but i know people who run 4:56s as their dd and commutes about 65 miles a day. i think he is in the low 3000 rpm range but he is young and can take the noise.
You are getting too old stangzilla, that is it isnt it?
#16 | |
That may be part of it and another part is the fact that I have a almost $7000 motor and dont want to put extra strain on it by spinning that much rpm on the highway when I am crusing long distances. I drive about 100 miles each way when I go to the track.. + when you are pushin 400+ hp without No2 like I am it really is not needed to have a gear that low because I have enough power to rip it up... If I had 4.56's in my car 1st and 2nd gear would be virtually useless.. its a good gear for a total drag car and for cars that are stock or mildly modded...
Shoot, that is why you need to get a trailor! LOL, just kidding man, I bet your 3:73s suit your setup well.
You think your block will hold just fine when the gas comes? I got it made, the track is 10 minutes from campus, and the only long commutes i make is home about once a month or so...about 280 round trip.
Yeah its fine I run a 175-200hp wet shot... But I have a stud girdle and a lifter valley girdle.. Good to 650hp.. Not gonna change my block until 4 or 5 years from now when my crate motor starts to get tired and I build my twin hair-dryer motor.. Then look out 9's here I come...!!!
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Possible causes are plugged cats, bad valve springs, retarded ignition timing, jumped timing chain, etc. The amp light coming on is odd. Is the belt slipping? Is there belt dust on the alternator fan/pulley?
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
95 opalfrost gt
A slipping belt came to mind first, but i didnt see if you checked your coil that would be my next guess.
Threads Similar to: Losing HP
| am i losing hp??? | franky | 99-04 | 26 | September 4th, 2007 12:30 AM |
| Losing streak | ByPopularDemand | V6 Mustangs | 15 | August 7th, 2007 08:28 PM |
| losing oil pressure | marks87gt | Engine | 7 | July 14th, 2007 07:27 PM |
| Losing Battery Power Somewhere *SOLVED* | 89 5.0 LX | 5.0 Mustangs | 20 | November 14th, 2006 02:59 AM |
| losing power | blak88stang_gt | General Tech | 1 | April 2nd, 2006 09:40 AM |
