Tips on lowering a fox body
Old April 11th, 2006, 08:54 PM   #1
92mustanglx is on a distinguished road
I have a 92 Mustang LX 5.0 I recently just perchased lowering springs. They're Gold-Line and will lower the car 1.3" If anyone has any tips for me or has encounter any problems when lowering a fox-body, I would appreciate your input.
Thanks!
Old April 11th, 2006, 11:04 PM   #2
1gunner23 is on a distinguished road
Are you doing it yourself? i put Eibach pro-kit in. with all new shocks and struts. make sure you have a pinion snubber to. let me know if your doing it yourself and i might be able to give some tips to help you out
Old April 12th, 2006, 11:01 AM   #3
IcantDo55 is on a distinguished road
Be carefull removing the stock springs.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old April 16th, 2006, 07:15 PM   #4
Yes I am doing it myself, not my first time lowering a car but first time lowering a mustang Fox Body. Any tips???
Thanks
Old April 16th, 2006, 11:48 PM   #5
invest in some coil spring compressors, or have a shop compress them and then band them. even thought they are drop springs, they go in pretty damn hard. also might be a good idea to replace your struts and strut bearings/bushings and a set of spring isolaters but thats just me. also remove your sway bar links to prevent breaking them when you release your struts, and the spring pressure. i did my on a car lift but reguardless use a floor jack to slowly relese the spring pressure, they will fly out of the spring perch if not properly restrained so just be careful. and more ?'s just let me know
Old April 17th, 2006, 02:01 AM   #6
OutFoxed's Avatar
OutFoxed is on a distinguished road
if you have too jacks, i think its easier too remove the control arm bolts rather than at the ball joint. 2 jacks is only too line up the holes easier when bolting back up, kinda tricky with one jack....but can be done
Old April 17th, 2006, 06:08 PM   #7
GTXRacing is on a distinguished road
REDO...
if you have two jacks, I think its easier to remove the control arm bolts rather than at the ball joint. Two jacks is only to line up the holes easier when bolting back up, kinda tricky with one jack....but can be done.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old April 19th, 2006, 01:08 PM   #8
combatcomprog is on a distinguished road
Do you recommend those springs over Eibachs?
Old April 19th, 2006, 10:53 PM   #9
this is just me, you may pay a lil more for the eibachs but they are well worth the money.
Old April 23rd, 2006, 04:21 PM   #10
I Will be installing the drop springs on a hoist at my shop and we also have a spring compressor, so that should make things a little easier...I bought a set of Eibach Springs and Shocks instead of Gold-Line, I've heard only good storys about the Eibach's. I will be starting this project next weekend Thanks for everyones input, well appreicated boys!
Cheers!
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17
Old April 25th, 2006, 09:47 PM   #11
no prob and good luck, i think you'll be happy with the ride, i know i was.
Old August 1st, 2006, 08:43 PM   #12
RARE NOTCHBACK's Avatar
RARE NOTCHBACK is on a distinguished road
I just put the ford racing springs in my notch. The front is a pain. the back is a piece of cake. The front control arm is the main consern. You
need to get it straight up and down to get the spring to catch the lip on the control arm. Once you do that it goes pretty easy.
Threads Similar to: Tips on lowering a fox body
Tips for Men. HMUSN The Clubhouse 42 September 2nd, 2007 06:18 PM
tips thetrooper31 General Tech 1 June 13th, 2007 10:30 PM
tips thetrooper31 V6 Mustangs 9 June 8th, 2007 01:54 PM
New Here ... Need Some Tips For 01 GT mst219 99-04 17 October 23rd, 2006 03:22 AM
will a 94' to 98' body style rear end fit under a fox body frankenstein 5.0 Mustangs 3 July 13th, 2006 09:53 PM
