1996 Cobra
Not fast enough.
Gears for cheap.
I just graduated HS a few days ago, and one of my dad's good friend who has been building rear ends for more or less all his life, said he'd build me a set of gears, whatever ratio I want, I just pay for the parts. Might as well do it right? But I was just wondering what ratio I should use...I was thinking 3.73's but I have these shitty street tires and they're about as wide as a Honda Civic's, so there's no way in hell that I'd beable to hook with these tires and those low(er) gears...Any suggestions?
Mods: Full 01 Cobra drivetrain (Teksid block ) T56, 3.73s, Pro 5.0, Aluminum driveshaft, JLT CAI, BBK O/R X, SLP LM1s, Full welded in sub frame connectors
1992 Lx
11.39@119.24
4.10s
1996 Cobra
Not fast enough.
1992 Lx
11.39@119.24
If you have shitty tires you arent gona hook with 2.73s or 4.88s, thats why you have a spare set of 10 holes with slicks
#5 | |
1996 Cobra
Not fast enough.
And they're shitty, yes, but they don't hook half bad with the 2.73's in there now...
1992 Lx
11.39@119.24
Yessir! Tons of people run slicks on a spare set of 10 holes, myself included on my last fox. No fox will hook good on the street when it has a decent amount of power so who cares, you mod it to run at the track anyways
1996 Cobra
Not fast enough.
Oh well this helps alot...I've been wanting to get a spare set of DR's or slicks, but I just figured they don't make slicks small enough to fit on stock lx 10 holes...So I figured I was gunna have to set up a 5 lug conversion and then buy a set of Welds or something like that...Where can I get these tires?
3.73 is the best gear ratio for a stockish T5 fox
2002 Mustang V6
how long does it take to push it?
You need to think about what your going to be doing later to the car, it will better decide what you get. Along with MPG and driveablity you want. Im going 4.10s, screw MPG
1996 Cobra
Not fast enough.
Well I don't drive it alot, so I'm not really crying about MPG...And I'm planning to do quite a bit in the future...But that's not for some time...
1996 Cobra
Not fast enough.
That's what I've been told...The guy that's building it for me said that 3.55's or 3.73's would be the best for what I'm working with now...
1988 Mustang 5.0 LX
12.48@118.27
if you drive an automatic and you get gears chances are that you are going to be cruzing down the freeway at a little to high of an RPM even wit OD on
2002 Mustang V6
everyone whos gotten 4.10s have never looked back
1996 Cobra
Not fast enough.
Yea so I've heard...If I can get these slicks for rims I'll get 4.10's.
My dad had 4.11's on his Z06 and that thing picked up....Fast. haha
95 Mustang GT
Where do you get your info? First off you just say with gears he is going to be at a high RPM in OD on the freeway so does that include 3.27's 3.55's 3.73's 4.10's ? Makes no sense, and second most people running AOD's end up going with 4.10's and a lot of the manuals go with 3.73's so please explain.
![]() People should think about boarding up their glass house before starting a rock fight! |
#16 | |
1995 Mustang GT
IDK Fast
1995 mustang GT- mods out the a** 1995 mustang- Parts, Parts 1998 mustang V6- was DD, now tranny is out
The best gear (if there is such a thing) is the one that puts you close to your shift point in 4th gear at the end of the 1/4 mile. Fine tuning is done with the tire size. If you spend a lot more time on the street, pick the combo based on your personal preference that is close enough to make you comfortable.
4.10's sucked balls in a pretty stock 92 gt I used to own.. first gear was completely useless and with the stock cam/heads it ran out of rpm in the quarter with the 4.10s
just an fyi |
1988 lx
9.68@142
ive got a set of 3.73's ill sell for $100 shipped
1996 Cobra
Not fast enough.
Really? Sounds good...I'll PM when I make up my mind, if you still have them around I'll take um off your hands.
Threads Similar to: Gears for cheap.
| speedo gears for 4.30 gears | bcinthearmy | 94-95 | 2 | April 23rd, 2009 12:02 AM |
| Cheap Cheap Cobra!!! | Squints | The Clubhouse | 15 | February 21st, 2009 11:34 PM |
| Any place that has gears for cheap? | Nick_Rapitis | V6 Mustangs | 3 | May 18th, 2007 10:42 AM |
| Cheap Cheap!!! 3.73 gears minor chips... Buy It Now $45 M/O | 00SoSlow | V6 Mustangs | 3 | August 5th, 2006 10:32 AM |
