Please Help Get My Pump Install right
Old April 11th, 2006, 09:36 PM   #1
GTXRacing is on a distinguished road
Ok, I have installed a Holley Red Pump and it works and everything. But I have one problem and that's the fuel leaking somewhere other than the hoses. So im going to ask this question so this will be done right the "2nd" time. First Here's my initial Installation...
1. Took the relay switch off the plug(Stop that old pump.
2. Removed the outlet hose of the fuel filter.
3. Inserted the inlet hose to the new inlet pump.
4. Connected stock hose of the (Outlet) side to the outlet side of the new pump.
5. Connected my wires like so and it works.
Now see'ing there's no leaks on the hoses, Im getting a leak on the drivers side. Also no fuel is showing up in the upper see through fuel filter. I followed the fuel hose from the carb back so assuming that's the outlet side, that's the side I disconnected from the filter and reconnected it to the new outlet side of the new pump.
Which hoses are what from the tank so I can install right tomorrow. I can't take the tank off so looking at the hoses as it's coming out the top. Please don't tell me I need a regulator(Already have one). Pump is already preset at 7PSI.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Threads Similar to: Please Help Get My Pump Install right
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 12:08 PM
Focus SVT Fuel Pump install gsjohnson 99-04 5 September 16th, 2007 02:40 AM
Mechanical pump, or existing in-tank pump? shnipplelicken 5.0 Mustangs 7 July 11th, 2007 11:47 PM
svt focus pump vs. ford GT pump undomesticfire 99-04 3 May 15th, 2007 07:10 PM
A1000 Pump With 255lph In-Tank Pump ? 92lx5oh 5.0 Mustangs 11 March 18th, 2007 08:51 PM
