Transmission Problem
Old April 12th, 2006, 05:51 PM   #1
173speed is on a distinguished road
what -up peoples well i just put a new clutch on my 88 mustang and put it back on the road after it had been siting for bout 8 month for the winter
first few days it was fine and then i started hearing a wining noise in second and third gear when the car is coasting and it seems that it is getting lauder specially when the car warms up after i been driving for a wile it sounds like there is two piece of metal spinning against each other and now I'm having problems engaging reverse and i hear the same wining noise but not as laud when i put it in gear forth and fifth gear sound ok the transmission was use when i got it 2 years ago and it sat for a few month before i put it in but it never did this before i did just purchase a new short-trow shifter for it but at first it drove fine with no noise any input with these would be appreciated...
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old April 12th, 2006, 07:47 PM   #2
vfast will become famous soon enough
did you replace the pilot bearing? new throw out bearing?
Old April 12th, 2006, 09:10 PM   #3
yes they are new but i do hear the throw out bearing a little bit
but it just seems that the noise is coming from inside the transmission
i could hear it where the shifter is
Old April 12th, 2006, 10:53 PM   #4
Did you adjust the shifter stops correctly? Sounds as if they may be adjusted out to far and also did you add any tranny fluid back after doing the clutch R&R? I'm sure you lost some dropping it out. try adjusting the shifter stops and draining the trans and refilling w/ mercon atf. Should take roughly 3 qts.
88 Mustang Coupe
www.rickscarcare.net
Old April 13th, 2006, 06:23 PM   #5
i will try that i put gm synchromesh don't know if I'm spelling that the correct way but i know a few guy that use these and live by it one guy had a 10 second fox and said that it was what he use in his mustang it is not a atf but it is real light in viscosity and i know all the import guys use these stuff ever heart of it? or any body using it ?
also i hear the same wining sound now when i put it in second and first but it is real soft but it is real obvious in third when I'm of the gas i did adjust the stops on the shifter but i will try again it seems that i`m always having problems with my transmissions had 2 autos and two 5 speed and always problems !!! thanks for the help
Old April 13th, 2006, 09:17 PM   #6
are the man Twist went home for lunch and change the fluid and mix some Lucas in with it and it made a big difference i don't think it was low but it takes the gears much better and they are not as loud i did see metal shavings in the old fluid prob going to buy another tko or rebuilt the one i have i do have a spare trany so is all good thanks for the help bro
Old April 13th, 2006, 10:57 PM   #7
no problem, glad I could help
88 Mustang Coupe
Threads Similar to: Transmission Problem
Transmission problem help please jtlogruss08 94-95 6 November 3rd, 2007 12:58 PM
Transmission or Clutch problem ? cobralini 5.0 Mustangs 7 May 23rd, 2007 11:44 PM
Transmission Problem? ricer_slayer 5.0 Mustangs 12 February 26th, 2007 07:32 PM
2004 Automatic Transmission Problem bdoss V6 Mustangs 0 January 10th, 2007 01:43 PM
Transmission Problem 623MUSTANG 99-04 4 August 10th, 2006 03:29 PM
