which cam to use???
Old April 12th, 2006, 06:51 PM   #1
gixxer1 is on a distinguished road
which cam to use???
1989 5.0 stock lower end(rebuilt),trick flow intake,mac headers,1.6 roller rockers,edelbrock performer heads, 30lbs injectors,accufab regulator,190 fuel pump,70 tb,70 spacer,5spd.
want it to be streetable and reliable. has 4.10 right now , will be installing 3.73.......which motorsport cam? thinking about b303 ,maybe f303......
Old April 12th, 2006, 07:38 PM   #2
vfast will become famous soon enough
well the 30# injectors are too big.....do you have to pass emmisions? if yes you can really only ise a single pattern cam
Old April 12th, 2006, 07:44 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Those injectors may be over kill, but they aren't going to hurt anything.
One of the smaller Trick Flow cams would work great.
Old April 12th, 2006, 07:45 PM   #4
the stage 1 will work with it's tighter c/l and more lift on the exhaust
I believe lift is 4.98-512 off the top of my head
Old April 12th, 2006, 11:00 PM   #5
IcantDo55 is on a distinguished road
I had an "E" cam for years and really liked it. Not to crazy for street driving and worked well with a blower and N20
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old April 13th, 2006, 08:53 AM   #6
what do you guys think about the b303 cam for this application? good street cam? also the sub harness for the oxygen sensors is missing. i should install that harness right? thanks
Old April 13th, 2006, 09:20 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The b cam is a flop. The E or F cam would be a better choice. Honestly the Ford cams are way out dated and old technology. There are much better options out there.
Old April 13th, 2006, 10:32 AM   #8
so which one would you guys choose for this motor? either motorsport or aftermarket? trickflow stage 1? crane? edelbrock? i need help chooseing......thanks
Old April 13th, 2006, 04:28 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Probably the small Trick Flow cam.
Old April 16th, 2006, 05:10 PM   #10
bourget_77 is on a distinguished road
I went smaller they ask for and it workes really good for mid and high and i havent had no problems in town.
Old April 19th, 2006, 01:16 PM   #11
combatcomprog is on a distinguished road
My B303 runs extremely smooth. Gas mileage is excellent as well.
Old April 20th, 2006, 05:31 PM   #12
Aliate X is on a distinguished road
Send a message via AIM to Aliate X
....you sure its a b-cam?
Everything + Nitrous
Old April 20th, 2006, 05:45 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Smooth is one thing. Making power is another thing. A stock cam runs smooth too. The B cam is a 20 year old design that is very inefficient.
Old April 23rd, 2006, 04:44 PM   #14
92mustanglx is on a distinguished road
I have a Crane Cam in my 5.0 and im very impressed with the performance. It sounds nice and has a range from 2200RPM to about 6000 RPM. If I were you I'd go with a Crane
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17
Old April 24th, 2006, 08:21 PM   #15
Agreed, a lot of people buy the B-cams just for the Idle. They have a really tight powerband (about 4000-6000) and it makes your car feel like a 2 stroke dirtbike, if youve ever ridden one.
The trickflow stage 1 is your best bet.
