old 302 blocks?
so are they stronger than the normal 5.0 block, do they make more horsepower, higher compression ratio, i have a chance to get a couple :wink thanks for yor answers
Ben |
Moderator
if you are talking about the mexican blocks then they are a little stronger, i think that they were in early 70's cars, not sure someone will come in and chime on the years.
![]() ![]() BUILD 2 IN PROGRESS |
Can't bust it up on the years but I can say during the early 70's era blocks, they were really strong. Mine is an 88 and I've purposly revved to 7 on stock and didn't blow a radiator hose nor overheated or broke so mine's pretty strong.
The 351 blocks from the 69-74 era were strong blocks as well being that I read that from a 5.0 mustangs magazine from a section of guys that build racing engines
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
yah im talking any were from the mid or earlier sixties to the mid seventies. thanks for the info keep it coming
If you're a roller guy, if i'm not mistaken the 91-94 models were rollor. if your looking for protection, the 69-74 era block will have you covered. You can make hella power out of those blocks. I plan on it once I find a 74 351 block
im just wondering if they can handle more then the 5.0 block without cracking in half
on the 69-74 block, how much crazy power was made? the guy also has acouple 351w's i might get but i might get both thanks for the info keep it coming!Ben P.S. will these blocks bolt up in a fox body? |
if your questioning the strength of the 5.0 block.maybe you should build a 351 they fit mustangs using a swap kit which is not expensive.check holcomb motorsports.com.
If you want a good block and can fork out the cash, get a dart iron eagle or world products Man O War block...STRONG BLOCKS. Lets just say they wil hold anything anybody on here will throw at it!
The early 302 blocks are alot beefier than the roller blocks. The cylinder walls are thicker and the main webbing is thicker as well.
thanks for the info guys, yah i realize that the dart blocks are really strong, but i have the opertunity to get older 302 blocks along with a couple 351w's too. so thats what im asking about. can they handle a 200 shot maby?
Ben |
I would think the 351 would...some guys say they will hold up to 650...Go for it..If you break it, you got a few more blocks anyway!
#12 | |
The last one I built made over 700 horsepower and had 300 sprayed on top of it. A friend of mine makes 880hp at the wheels with a production 351W block and an F1R Procharger. Early 351W blocks are pretty strong for a production block.
Darrell.. I think I found the block I can get thanks to beleive it or not, that 88slg or whatever guy I was mean to(Sorry about that dude!).
Anyways it's a 72 351 ans was told anywhere from 69-76 were perfect to hold 650 and any turbocharger would not hurt it with great head gaskets.
how about this 69-74 302 or 351 w/ Twisted wedge heads, stage II cam, victor Jr. intake, 650 or 750 carb (barry grant), long tubes, 200 shot of nitrous, and if needed forged internals( of course), plus msd ignition components. sound good for a 93 notch back?
plus the suspention too. Ben |
Sounds killer man, do it.
thanks im hoping for at least 450whp if not more. probably have to go 351 for that
#17 | |
I'd use a bit more cam like the TFS stage 3. Stick with a 750. I prefer Holley HP but Barry Grant is ok. Just make sure you thoroughly inspect the carb for metal shavings internally. That has been an on and off problem for Barry Grant carbs. Look into Team Z Motorsports for your rear suspension. That is what I run on my car and I 60 foot 1.32 on 10.5 inch tires. I've used pretty much every rear suspension set up out there. Team Z is in my opinion the best value out there. www.teamzmotorsports.net
thank you very much. Darrel what ever you say i'll probably end up doing. now what carb was that exactly( link?)
what suspention componets do u recomend from them. i also know im going to get a tubular k member soon. with all those components what times do you think i will run? 11's...10's maby
#20 | |
Threads Similar to: old 302 blocks?
| 302/351 blocks | sleepinggt | 5.0 Mustangs | 4 | September 17th, 2007 12:48 AM |
| Engine Swap: Small Blocks or Big Blocks | Speedstang302 | 5.0 Mustangs | 32 | April 15th, 2007 11:34 AM |
| Anyone Know About Stock Blocks? | 89GTCONV | 5.0 Mustangs | 8 | March 31st, 2007 04:46 AM |
| Big Blocks In 64, 65, 66 Mustangs | apercy | Classic Mustangs | 28 | February 28th, 2007 07:55 PM |
| 4.6 blocks | beheivjer | 96-98 | 1 | January 19th, 2007 12:36 PM |
