coolant leaking here i think. - Page 2
Old March 22nd, 2007, 10:18 PM   #21
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
Originally Posted by mikebert
Originally Posted by IcantDo55
Originally Posted by SALIV8
The coolant does not go into the timing chain's cover.
No! It does. It flows through the cover to the block and is common to have a timing cover to block gasket fail. I just did one last week on my 5.0 Bronco.
SBC don't have coolant through the timing cover, SBF do.
Thank you, I could have sworn that the timing cover had coolant passages. I thought maybe I was going insane and I'm not at home to check a timing cover gasket. I kinda wondered how the water pump sat on one side of the timing chain cover and magically pushed water around the the block.
thanks for the correction guys, my bad
Threads Similar to: coolant leaking here i think.
Top leaking jblood37 99-04 8 September 19th, 2007 01:00 AM
my car is leaking? brianm 99-04 17 September 13th, 2007 11:49 PM
Leaking coolant,hot climate, not good zinc76 99-04 14 May 9th, 2007 07:30 AM
HELP!!! Coolant leaking out exhaust.... lwhitetrash88l V6 Mustangs 23 April 6th, 2007 02:40 PM
Leaking Coolant From Where tranmission meets Block garyvang 5.0 Mustangs 0 April 25th, 2006 05:00 PM
