1989 GT Hatch
coolant leaking here i think.
so does the coolant run from the water pump thru the timing case into the block? it looks like the gasket between the block and the timing casing is leaking a few drops of coolant?
also am i stupid to not change out the water pump while i'm doing that? the water pump is fine, but most likely stock still. 1989 gt 5.0 5-speed (stock for now) |
if your car is stock, i would suggest changing all the hoses, and changing coolent. if you have the money yes get a hi flow water pump, but dont get an electric water pump, they wont be as efficient.
The coolant does not go into the timing chain's cover.
1989 GT Hatch
Can i just go with a Summit Racing hi-flow water pump they are only $67.
I had been looking for the leak right after driving it, so the coolant drops were blown all over from the wind. Then I guess it is the water pump gasket. I'll do the a/c delete, hi-flow water pump, 180* thermostat (i think there is a 160* in), and a coolant change. |
Make sure you check the gasket coming off the intake manifold where the thermostat is also. Sometimes those leak and its hard to see if its the water pump or that cause the coolant runs down the side of the water pump. A dead giveaway of that (or the hose) leaking is coolant puddling on top of the timing chain housing behind the water pump.
if you get a W/P and use a serp. belt use a reverse rotation pump
#7 | |
1989 GT Hatch
#8 | |
Re: coolant leaking here i think.
It could be coming from where you said but also could be coming from the pump it self.. Replace the pump too...
#9 | |
1989 GT Hatch
#10 | |
SBC don't have coolant through the timing cover, SBF do. |
The gasket on the far right is the timing cover gasket and the two round holes in there are your coolant passages, thats your problem.
#12 | ||
Thank you, I could have sworn that the timing cover had coolant passages. I thought maybe I was going insane and I'm not at home to check a timing cover gasket. I kinda wondered how the water pump sat on one side of the timing chain cover and magically pushed water around the the block. |
1989 GT Hatch
Thanks everyone, I have a Chitons Manual in the mail. So it that water pump ok?
Honestly, from what I've heard, those summit cheapy but working water pumps are only for your stock motors, if you plan on power, you might want to invest into another one. Might cost ya more but better for your engine too.
Now that's what I heard, not official since I haven't done it yet but hell my stock w/p does great for what I have.
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
#15 | |
#16 | |
Summit sells a high volume water pump. I have one on my 347 it works fine. They claim it flows 30% more than stock. I also put in a high flow Moroso 180 degree thermostat to aid in the flow of the high flow water pump..
#17 | ||
Oh ok well there's your answer dude. Stangzilla, how far are you from Texas?
1989 GT Hatch
i already have a 180* thermostat but it isn't a high flow, should i not waste my time putting it in unless it is a high flow?
Well it helps if you have a high flow water pump to have a high flow thermostat as well.. Its like 10 bucks.. Get it..
#20 | |||
Too far bro I live in Upstate NY... If you ever come to NY let me know...
Threads Similar to: coolant leaking here i think.
| Top leaking | jblood37 | 99-04 | 8 | September 19th, 2007 02:00 AM |
| my car is leaking? | brianm | 99-04 | 17 | September 14th, 2007 12:49 AM |
| Leaking coolant,hot climate, not good | zinc76 | 99-04 | 14 | May 9th, 2007 08:30 AM |
| HELP!!! Coolant leaking out exhaust.... | lwhitetrash88l | V6 Mustangs | 23 | April 6th, 2007 03:40 PM |
| Leaking Coolant From Where tranmission meets Block | garyvang | 5.0 Mustangs | 0 | April 25th, 2006 06:00 PM |
