Water pump
Old March 21st, 2007, 10:52 PM   #1
90Stang's Avatar
2005 Mustang
12.9@109
90Stang is on a distinguished road
Send a message via AIM to 90Stang Send a message via MSN to 90Stang
Water pump
Ok on a 1990 5.0 serpentine setup the water pump is a reverse flow correct. i want a water pump that will bolt up and turn the opposite way as my stock one..... what year 5.0 should i order one for
Old March 21st, 2007, 11:14 PM   #2
Racinjason81 is on a distinguished road
no.the only exception is if you are using a v belt cuz it turns the other way. use a 87-93 5.0 mustang waterpump
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old March 22nd, 2007, 09:10 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Water pump
I have to ask why? Just so we are all on the same page. Did you switch to a v-belt set up?
Old March 22nd, 2007, 01:34 PM   #4
90Stang's Avatar
2005 Mustang
12.9@109
im deleting the a/c, powersteering and i want to run the belt over the water pump which makes it spin the opposite way that it does now. or is there a kit that i can buy that puts an idler pulley wher the ac went.
Old March 22nd, 2007, 02:12 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Run the belt over the tensioner pulley instead of under it. Then you can run the water pump in the right direction. I've done it this way many times. I believe the belt size is either 443K6 or 413K6.
Old March 22nd, 2007, 02:16 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Old March 22nd, 2007, 07:15 PM   #7
90Stang's Avatar
2005 Mustang
12.9@109
i have it that way now and the belt squeals. i found a bracket that march makes that moves the tensioner where the ac goes that will solve my problem. thanks for the help.
Old March 23rd, 2007, 02:19 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What belt size are you using 90Stang? The right size belt is a bitch to get on but will not squeal. You have to loosen the alternator and push it forward (toward the tensioner) as far as it will go and then squeeze the belt on. Then use a pry bar to pull the alternator back and stuff the bolt back in the top.
Old March 23rd, 2007, 04:36 PM   #9
GTXRacing is on a distinguished road
Just a question because I never done it before... What's the point of removing the power steering? A/C I can understand maybe to free up some extra hidden hp.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old March 23rd, 2007, 04:56 PM   #10
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Removing power steering can take a out chunk of weight on the front end. If it's not your daily driver (or you're just a burly fucker) then switch over.
Old March 24th, 2007, 01:02 AM   #11
1989 GT Hatch
YNOT is on a distinguished road
reverse flow is counterclockwise right?
Old March 24th, 2007, 01:50 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It really doesn't free up any horsepower but it removes about 50 pounds of weight and sure looks alot nicer.
Old March 24th, 2007, 01:50 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes.
Old July 8th, 2007, 04:57 PM   #14
JYeagamista81 is on a distinguished road
Over heating 85 5.0
OK I have an 85 5.0 that I just built with Afr heads, e303 cam, hyperthecnic pistons and so on. It is a carb set up. I had ordered the same water pump that was on the original 5.0 and watched as I satarted the car that it spins the blades on the pump the wrong way. The pump is pulling towards the passenger side and the fins are turning towards drivers side. and it was flowing out of my radiator bad. So I bought a pump for a 93 5.0 and thta spins towards the passenger side. But I am still over heating. way past the h. I also removed the ac and air pump with kits. the heat out of the vents is nice and hot and both heater hoses get nice and hot, but once it over heats in a matter of 5-10 mins you hear it bubble in the radiator. I did air lift the engine before I installed the coolant. Anybody out the have any ideas on what I can do next?? I could use any kind of info. I also have a 180 degree thermostat in it. Thanks
Threads Similar to: Water pump
Bad Water Pump? gotboost562 5.0 Mustangs 18 April 4th, 2012 06:31 PM
water pump 95wip 94-95 6 May 23rd, 2007 09:03 AM
Water pump ??? Fastback GT Classic Mustangs 15 February 24th, 2007 02:37 PM
Water Pump cobralini V6 Mustangs 1 August 3rd, 2006 06:48 PM
water pump going? magnifistang 5.0 Mustangs 8 January 12th, 2006 09:49 PM
