Deleting A/C and smog
When deleting both of those, do you have to relocate the power steering? And if so, do you have to buy some kind of bracket?
I believe you can get kits that just bolt pulleys into the locations of the smog pump and A/C.
However, for cars that didn't come with AC, the power steering pump is in a different place. So if you have seen kits with complete brakcets, it's going to be a setup like you never had A/C, as opposed to a placeholder pulley. |
no not neccesarily if you use a march a/c eliminator the P/S stay where it is and if you use a air pump idler
#4 | |
Re: Deleting A/C and smog
I of course have neither of those on my car.. What I did was bought the March alt bracket kit that allows the adjustment of the belt with a rod on the alt. I have no tensioner. My power steering is in the same place. I just made a couple a trips to the parts store to size up the belt. I have had to only had to adjust the belt tension once so far a week or so after install prob due to inital stretching.. I like my set up without the tensioner...
1990 LX hatch
OK, first off I know its ghetto....
I took them both off and relocated my tensioner on the AC bracket. you have to drill a hole in it and get a nut for the bolt. you can leave everything else where it is.
At least you admitted it...LOL
1990 LX hatch
Yea, Ikeep a pretty clean engine bay, but I allways feel I have to explain myself before I pop my hood for anyone because of that.
has anyone does a ac,smog & a PS delete and what did you have to do.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
PS delete? You don't plan on driving on the street a lot?
not very much. i have put skinny tires up front and it is mostly used for the track. i will drive it on the street just to brake in the motor. only 500 miles on it now.
PS is leaking bad, and i can have that on the strip
Well, I think you need a kit to get rid of PS. It's not just the same as disabling the PS pump. Plus, since you're using it for a track application, there is a bit of weight reduction to be had from swapping the system over.
ya. i am looking at ebay ,i may just replace the rack.
? just got the new motor in and the dam thing starts to leak. would have been really easy when the motor was out
I wish the previous owner of my car never deleted my ac, now I have to find all the parts to put it back on. Bleh.
2000 A4 Z-28 Free Mods No Appearance or Performance mods Yea, it's slow.....
#16 | |
Or buy from the people that are asking about delete kits? |
#17 | ||
#18 | ||
Most people have the r12 units which I heard you can't recarge or are expensive to do so. I might buy a r134 kit off of 50resto, it's 799 tho =T
#20 | |
Threads Similar to: Deleting A/C and smog
| DELETING SMOG PUMP | BROKINARROW | 5.0 Mustangs | 5 | October 9th, 2007 07:32 PM |
| Deleting egr valve on 5.0 | lugthug713 | 94-95 | 11 | August 23rd, 2007 02:17 PM |
| Help with deleting smog equip. | 1fastsedan | 5.0 Mustangs | 3 | March 8th, 2007 02:00 PM |
| Is Someone Deleting My Topics? | 00SoSlow | The Clubhouse | 15 | September 16th, 2006 12:17 PM |
